troubleshooting soft clutch
Old Dec 6, 2004 | 09:45 PM
ludefan'94's Avatar
Default troubleshooting soft clutch
sup guys, noob here and having problem.
got in my car today at lunch, and my clutch has become really soft. engages really low to the floor, yadda yadda yadda, i read the threads.
so i check the fluids on the master/slave cylinders, both toped off.
take the caps off, and pumped the clutch. fluids dont move and no bubbles or anything. checked for leaks under the clutch petal... nothing. so that should mean my master/slave cylinders are fine right? what should i be checking next? and what else could be the problem? gears glide in and out just fine but only when the clutch is fully stepped on. i appricate any help, thanks.
btw i got a 94 prelude si with a jdm h22a swap. replaced the master/slave cylinders durring the swap. jdm h22a tranny grenaded also after the swap and that was replaced as well.
Old Dec 6, 2004 | 09:52 PM
Hawkze_2.3's Avatar
Default Re: troubleshooting soft clutch (ludefan'94)
Check the tranny oil also
Old Dec 6, 2004 | 09:58 PM
ludefan'94's Avatar
Default Re: troubleshooting soft clutch (Hawkze_2.3)
chilton says i gotta remove the oil filler bolt on the side of the transaxle? any easier way of check the tranny oil?
Old Dec 6, 2004 | 10:00 PM
Hawkze_2.3's Avatar
Nope, just make sure it's on a level surface, undo the bolt and fill it up until it spills out (pour slowly). I usually stick a funnel with a long hose on the end down there...
Old Dec 6, 2004 | 10:02 PM
ludefan'94's Avatar
alright thanks alot *props*, guess ya gotta do what ya gotta do.
Old Dec 6, 2004 | 11:09 PM
SKDRCR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ludefan’94 &raquo;</TD></TR><TR><TD CLASS="quote">
take the caps off, and pumped the clutch. fluids dont move and no bubbles or anything. .</TD></TR></TABLE>
So you did bleed the system?
Old Dec 7, 2004 | 07:13 AM
ludefan'94's Avatar
Default Re: troubleshooting soft clutch (SKDRCR)
no not yet. trying to get some free time.
Old Dec 14, 2004 | 12:09 AM
vtec_crazy's Avatar
have u check out ur clutch plate.
btw iwhat if u have a leak under the cutch pedal.
what does that mean cuz my clutch is not bad but only grabs up high,.
and i cant adjust it cuz its hydrolics
and no oil leaks or missin oil anywhere just saw a liwquid under my clutch pedal
hmj88hb
Nov 18, 2006 07:57 AM
ludedude808
Sep 4, 2006 12:33 PM
IlIkEg's
Oct 18, 2005 08:09 PM
Drizzo
13
Aug 5, 2004 08:44 AM
k-man
Jul 24, 2003 07:04 AM
