Aftermarket Tach
Old Dec 6, 2004 | 07:38 PM
EJ8 GSR-T's Avatar
Default Aftermarket Tach
A friend of mine gave me his aftermarker tach, and its cool so why not install it? So i looked into it and there are like four or five wires. I assume ground, power, dim, and the rmp (ill call it rpm input) I really dont want to splice into my distrubutor becuase that required running wires into the engine through the firewall, which blows. So my question is dose anyone know of the exact wire that is somwhere behind the dash that will give me what im lookin for? my cars a 98 civic ex
Old Dec 6, 2004 | 07:42 PM
nighttrain33's Avatar
Default Re: Aftermarket Tach (userdead626)
You can't just unplug your tach and plug the harness into the aftermarket tach?
-Shane
Old Dec 6, 2004 | 07:43 PM
civic_hatchy's Avatar
search the archives theres alot of info on installing aftermarket tachs
Ricey McRicerton's Avatar
Default Re: Aftermarket Tach (nighttrain33)
What "exact wire"? You'll need one for the power, one for the light switch, one for the ground, and the RPM input signal wires.
Built Beast's Avatar
signal wire is blue, you can tap into it (upper right corner of the engine bay, closest to the driver side...the signal wire is the "rpm" wire, you can tap into it at the dizzy up to you.
Old Dec 6, 2004 | 07:45 PM
EDITED...
Modified by R33CIVIC at 11:55 PM 12/6/2004
Old Dec 6, 2004 | 07:54 PM
Default Re: Aftermarket Tach (R33CIVIC)
I'm sorry, I was thinking one in the gauge cluster. Stupid me. Sorry for the post. Maybe we should just forget I said that.
-Shane
Old Dec 6, 2004 | 07:57 PM
SRCivic97's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nighttrain33 &raquo;</TD></TR><TR><TD CLASS="quote">I'm sorry, I was thinking one in the gauge cluster. Stupid me. Sorry for the post. Maybe we should just forget I said that.
-Shane</TD></TR></TABLE>
We could forget, but it's entirely much more fun to flame you hehe
After Market Tach will have more than the positive and negative wires. You will have two wires for the lighting alone, one (blue) for the sensor and the other two give the tach itself power.
Old Dec 6, 2004 | 07:58 PM
eL`mIEkLo's Avatar
trash it....no need probably why he gave it to u
Old Dec 7, 2004 | 07:38 AM
sinister6's Avatar
Im thinking of getting one as well. but then now i figular stock CTRs tach can goes up to 10k i will be happy to find one. hate those big thing beside A-pller
Old Dec 7, 2004 | 11:44 AM
EJ8 GSR-T's Avatar
Default Re: (sinister6)
**** dose anyone know where the rmp signal wire can be tapped into under the dash?
Old Dec 7, 2004 | 12:08 PM
Daniel_san's Avatar
Default Re: (userdead626)
theres a blue wire that is wired to your stock cluster.
but that goes through a whole bunch of **** and filters, hence the reading not being 100% accurate, hence getting a aftermarket one.
but if you're using the same input, It'l still suck.
do it right, and plug it to you distributor. it's only 1 wire.
if yo dont' have AC, there a nice big hole for you near the battery on the passenger side for you.
Acidcrakker
Nov 17, 2011 11:52 AM
mowdy1980
Jul 6, 2007 10:41 AM
slimjimdanny
Jan 31, 2007 07:35 PM
bbhockey19
10
Jul 11, 2006 09:10 PM
