water in drivers area
Old Dec 6, 2004 | 06:11 PM
hOndafienD 04's Avatar
Default water in drivers area
everytime it rains i always have water inside my drivers side area....is there a drain that runs along those lines that might be clogged? its annoing because it stinks up the car when its really bad.
Old Dec 8, 2004 | 04:43 PM
bump...i know there has to be another luder with the same problem as me.
Old Dec 8, 2004 | 05:11 PM
aboh6leenz's Avatar
Default Re: (hOndafienD 04)
I get a little bit of water in the trunk. But my sealings are a little worn/ripped.
Old Dec 8, 2004 | 05:17 PM
Default Re: (aboh6leenz)
yeah thats prob from the trunk seal, bt when it rains hard, it gets soo bad that it reaches the rear seat, and my pants always get wet because they touch the water.
Old Dec 8, 2004 | 05:44 PM
americ_ian's Avatar
check the rubber bung on the inside of the fusebox, i had to real seal mine, but my car is RHD, so im not sure abot LHD
Old Dec 8, 2004 | 07:01 PM
will do....this **** sux!
Old Dec 9, 2004 | 05:40 AM
flyrod's Avatar
There are four hoses that drain the gutter around the sunroof. Make sure they are not clogged with leaves and crap. This is what happened to me. If you open the sunroof and pour a glas of water into each corner of the gutter it should come out on the ground.
Old Dec 9, 2004 | 09:35 AM
will be doing this before the next time it rains hopfully
Old Dec 9, 2004 | 11:13 AM
aboh6leenz's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by flyrod &raquo;</TD></TR><TR><TD CLASS="quote">There are four hoses that drain the gutter around the sunroof. Make sure they are not clogged with leaves and crap. This is what happened to me. If you open the sunroof and pour a glas of water into each corner of the gutter it should come out on the ground.</TD></TR></TABLE>
If it is clogged how do you uncolg it?
Creature1
Honda Civic (2001 - 2005)
May 5, 2014 10:13 AM
biscuit01ex
Apr 30, 2006 11:20 PM
PatrickGSR94
Jan 30, 2005 02:38 PM
Truecure
Nov 3, 2004 12:33 PM
crxaddikt
Oct 28, 2002 02:35 PM
