jun3 camed h22 dyno
i posted this in NA, but i figured you people that only post here would like to see this as well
this motor is basicly the same as the one that we did the cam test on, with the exception of new valves cause all the exh valves were bent when we dyno'd the other cams, and it has jun stage 3 cams, it still has stock block and other than new valves a stock head
the red line was base line done on a previous tune, green was after cam gear tuning (only on the intake side) and swapping from a dookie 2.5 inch accord aem cai and 58mm throttle body to a semi getto 3inch intake and 68mm throttle body
getto 3inch intake
68mm tb
euro r intake manifold
stock head with ferrea valves
rocket springs/retainers
jun3 cams
one hayame cam gear on the intake side, stock gear on the exh
and to top it all off a ebay weapon r header with the collector loped off and 2.5 inch pipe welded on
all tuned by me with an aem ems
this is the same motor we tested the rocket regrinds on, just that all the exh valves were bent when we did that test... here is the link to that thread. https://honda-tech.com/zerothread?id=1017085
EDIT: i probably should mention that this was done open header as well
Modified by JDogg at 1:22 AM 12/7/2004
getto 3inch intake
68mm tb
jun3 cams
Why does it say "flywheel" for the graph?? 217 at the flywheel is attainable with just regular bolt-ons. That normally makes it like 180-190-ish at the wheels .......
217 at the wheels would be quite nice!
thats a quirk in dynapack software... they always say "flywheel power"
see the TCF number at the bottom, thats transmision correction factor, if you set that to 1.15 then it will compensate for a 15% loss in power through the tranny... thus it becomes flywheel power.. set it to 1.00 for actuall numbers.
prelittlelude.. im on aim most of the time.. feel free to IM me.
Do you think that motor will have any problems running the JUN stage III's with the rocket valve springs/retainers? Because JUN clearly states that the stage III's can only be used with their own JUN valve springs and retainers, but I have a hard time believing that. And maybe I just can't bring myself to spend almost $1K on valvetrain components
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hOndafienD 04 »</TD></TR><TR><TD CLASS="quote">nice top end!!! hows the idle? just wondering....</TD></TR></TABLE>
well, the iacv wont fit in the civic w/the euro r manifold, so we have a big vac leak to make it idle.. when its cold its a very lumpy 800-900 rpm idle, once it gets warm its a smooth but slighly lumpy sounding 1300-1400
its not really annoying... lol, it has no exhaust and i wear ear plugs when i drive it... lol.. its getting a different intake mani soon so we arent too worried about it.. this car was put together for testing purposes... expect more dyno's soon
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Honda318dx »</TD></TR><TR><TD CLASS="quote">Those are good numbers man..
I love my Jun cams too! </TD></TR></TABLE>
yeah.. just wish i had a good header...
the tq curve looks funny b/c of the scale.. look how small it is. on a dyno jet it would be smooth. that and the weapon r header always produces some wavyness.
it has aem ems and 750cc injectors
i listed the setup... reading is key.
stock h22 ecu sucks.. even with type s cams we picked up over 10hp through just tuning. this setup probably wouldnt run with a stock ecu. back in the day when we had type s cams, it went really lean in vtec... im sure it would be an even worse situation with this setup.
jun only makes stage 3 for h22.. .
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iakona »</TD></TR><TR><TD CLASS="quote">how much of a difference in tuning do you think the AEM has in a situation like this? as compared with running a stock Honda H22 ECU?</TD></TR></TABLE>
look at the graph, first run in untuned, 2nd is tuned
i love my Jun cams too! and Jun valvetrain!
Unfortunatly ive blown to much money to retune, gotta wait till after xmas, damn presents. I baselined at 190 untuned with full exhaust and stock intake manifold and stock clutch/flywheel with a crappy AEM filter. Oh also i had no cam gears at the time, now i got me some STR's
my fingers are crossed for the new graph.
