ctr cams or bc spec 3+ on b16a2 engine???
Old Dec 6, 2004 | 02:11 PM
kenepo_vtec's Avatar
Default ctr cams or bc spec 3+ on b16a2 engine???
I want to know wich of this cams will bring more hp and performance in my b16a2 all motor........
this is my set up:
b16a2 engine
stock head
cold air intake
p30 pistons
header 4-1
2.5 exhaust
msd 6a
aem cam gears
ys1 tranny
7.5 lbs flywheel
act clutch
pm6 ecu chipped
Old Dec 6, 2004 | 05:39 PM
Kataku2K3's Avatar
Default Re: ctr cams or bc spec 3+ on b16a2 engine??? (kenepo_vtec)
Since your motor is basically internally stock just stick with the R cam. You don't have the compression to support big cams and would probably make less power with them.
RyanR
11
Mar 30, 2006 03:54 AM
kenepo_vtec
Dec 28, 2004 07:50 PM
kenepo_vtec
Dec 6, 2004 02:33 PM
zville00si
Feb 24, 2004 09:29 PM
mj_speed
Dec 17, 2003 12:11 PM
