oil psi?
Old Dec 6, 2004 | 01:18 PM
Mike banX's Avatar
Default oil psi?
i have a ls vtec with type r head. my oil psi used to be 75 at like 3 grand. now its like 90 at 3 grand? this just started after i changed my oil and filter
Old Dec 6, 2004 | 03:27 PM
drdisco69's Avatar
Default Re: oil psi? (Mike banX)
An old filter can cause a pressure drop. I can tell when the filter is clogged on my Corolla because the oil pressure gauge doesn't go beyond halfway. Quick change and back to normal.
Old Dec 7, 2004 | 11:00 AM
Mike banX's Avatar
when the car is warmed up compltely and im driving, is 95 pounds of pressure too high at 3 thousand RPMS?
it used to only reach 75 at 3 grand.
Old Dec 7, 2004 | 11:11 AM
mmuller's Avatar
Mad Scientist
Default Re: (Mike banX)
90 is high, it should be around 70 at 3k
Old Dec 7, 2004 | 12:19 PM
msmotorsports's Avatar
What weight oil are you using? It will make a difference in oil pressure.
Old Dec 7, 2004 | 02:18 PM
d.str0y's Avatar
90 is pretty high.
Old Dec 7, 2004 | 02:29 PM
EJ1 wilcox's Avatar
Default Re: (onezexycrx)
Is it an electric or mechanical gauge?
I have an electric gauge and the sensor got clogged one time and my readings were all funky for a while, then I cleaned it out and it started working again....
You shouldn't be at 90 psi @ 3k when your car is warm...I only get that high when my car is cold....
That's weird man..
Old Dec 8, 2004 | 05:26 AM
Mike banX's Avatar
im using 10w40. gauge is mechanical. could it be that i have to much oil?
standbackimapro
Apr 30, 2006 07:22 PM
mister2racer
Jun 3, 2004 03:46 PM
Nfurno
Dec 27, 2003 06:48 PM
toooslow
Jul 22, 2003 03:06 PM
degradated
Oct 29, 2001 07:04 PM
