Comp Cams - Do they eat rocker arms?
Old Dec 6, 2004 | 10:26 AM
Mr_GaBIG's Avatar
Default Comp Cams - Do they eat rocker arms?
Hello,
I have a set of Comp 57200 cams that I want to install in my B16A2, I have heard that these ruin the rocker arms.
Has anyone heard of this before or is it just a myth?
Thanks
Old Dec 6, 2004 | 10:43 AM
Spade's Avatar
Default Re: Comp Cams - Do they eat rocker arms? (Mr_GaBIG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr_GaBIG &raquo;</TD></TR><TR><TD CLASS="quote">Hello,
Thanks </TD></TR></TABLE>
Never heard that before.
Old Dec 6, 2004 | 10:55 AM
Mr_GaBIG's Avatar
Default Re: Comp Cams - Do they eat rocker arms? (Spade)
Excellent, more feedback the better
Old Dec 6, 2004 | 10:59 AM
JDMisGOOD's Avatar
never heard that before either!
Old Dec 6, 2004 | 12:52 PM
Mr_GaBIG's Avatar
Default Re: Comp Cams - Do they eat rocker arms? (JDMisGOOD)
Now my face looks like this
More posts like this and it will start looking like this
Old Dec 6, 2004 | 01:04 PM
Jim Truett's Avatar
I think the use of the proper moly based assembly lube will prevent galling upon inital startup and break-in.
Old Dec 6, 2004 | 05:26 PM
Mr_GaBIG's Avatar
Default Re: Comp Cams - Do they eat rocker arms? (Jim Truett)
Whats the comp lube made out of?
Where would I be able to get ahold of a moly based assembly lube?
Old Dec 7, 2004 | 06:31 AM
Mr_GaBIG's Avatar
So what do you guys think of the cams or
Old Dec 9, 2004 | 11:16 AM
civicsit's Avatar
whats going on??
i have those same cams for my gsr motor i have yet to put them in.. i havent heard of that problem eating rocker arms but ill tell you next moth tho when i get my head back from getting ported.
Old Dec 9, 2004 | 11:20 AM
Deemeetree's Avatar
Electrician
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr_GaBIG &raquo;</TD></TR><TR><TD CLASS="quote">Whats the comp lube made out of?
Where would I be able to get ahold of a moly based assembly lube?</TD></TR></TABLE>
Any cylinder head assembly lube will work just fine. Best thing to do is grab a gob of it in your hands and stroke your new stick () full of lubrication.
If they ate away at rocker arms, they wouldn't make them at all.
Old Dec 9, 2004 | 12:04 PM
00Red_SiR's Avatar
All Motor Mentor
Default Re: Comp Cams - Do they eat rocker arms? (Dimi)
Eating rocker arms only happens when no assembly lube is used or if the valves are over adjusted putting to much tension on the entire valvetrain assembly. Install any cam improperly and over adjust the valves and this kind of thing will happen.
Old Dec 9, 2004 | 01:03 PM
Mr_GaBIG's Avatar
Default Re: Comp Cams - Do they eat rocker arms? (00Red_SiR)
Excellent so these cams will be going on then
Should give some nice power gains once they're on
civicsit - What intake manifold you going to run on the GSR motor?
Old Dec 9, 2004 | 01:13 PM
Deemeetree's Avatar
Electrician
With tuning of course.
Old Dec 9, 2004 | 04:00 PM
Mr_GaBIG's Avatar
Does anyone know what the cam timings should be on a B16A2 with these cams?
Int = +2
Exh = 0
I might setup the cam timings to this.
Once I have time and money I will tune the cams properly.
Old Dec 9, 2004 | 05:08 PM
CTREGSIX's Avatar
Hey i was wondering what stage cams u got, cause i heard that comp only makes stage 1 and Full Drag. Is that true? Also what do they usually run for?$ thanks
Old Dec 9, 2004 | 06:33 PM
Mr_GaBIG's Avatar
Default Re: Comp Cams - Do they eat rocker arms? (CTREGSIX)
Comp do 3 stages.
57100 - Stage 1
57200 - Stage 2
57300 - Stage 3
They do a stage 4 aswell but thats for real racing...no need for that
Old Dec 9, 2004 | 06:56 PM
lilredhatch's Avatar
I've been runnin the 57200's in my mildly bult B18C1 for 1400 miles, no probs so far. Make sure u get matching valve train or a valvetrain that will handle the cams(skunk, kms, ect..)
You'll never know good cam timing till u strap it to the dyno...
Old Dec 11, 2004 | 04:21 PM
Mr_GaBIG's Avatar
Default Re: Comp Cams - Do they eat rocker arms? (lilredhatch)
Anyone else have 57200's on a B16?
Old Dec 15, 2004 | 08:03 PM
matt2001teg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lilredhatch &raquo;</TD></TR><TR><TD CLASS="quote">I've been runnin the 57200's in my mildly bult B18C1 for 1400 miles, no probs so far. Make sure u get matching valve train or a valvetrain that will handle the cams(skunk, kms, ect..)
You'll never know good cam timing till u strap it to the dyno...</TD></TR></TABLE>
Can you run these cams on a stock valve train. I know type r and skunk 2 stage 1 you can.
Old Dec 16, 2004 | 09:58 AM
Mr_GaBIG's Avatar
Default Re: Comp Cams - Do they eat rocker arms? (matt2001teg)
Someone on this forum is running these on a stock B16A2, however you will need to upgrade if you go above 8000rpm
Old Dec 16, 2004 | 05:58 PM
i'm almost positive u must upgrade the valvetrain to run the B series 57200's. check the Comp or Zex website..
lude98SH
16
May 16, 2008 07:25 PM
panda_eh2
Apr 18, 2008 12:17 PM
EVOL TYRONE
May 24, 2007 06:03 AM
alpha
Dec 27, 2005 07:18 AM
jdmcoop
15
Sep 8, 2005 03:40 PM
