Rocker arms
Old Dec 26, 2005 | 05:42 PM
alpha's Avatar
Default Rocker arms
With the racing season over I am curious. How many of you check your rocker arms for wear? How often are you replacing them? I'm putting a third set of cams, second set of large cams, in my head with 45,000 miles on the rocker arms so I figure either way it's time.
Thanks
Old Dec 26, 2005 | 06:24 PM
hondaguyef's Avatar
Default Re: Rocker arms (0x64)
I check mine and if one looks like the pad is showing signs of wear I replace it. I run OE cams and don't rev high though so, my valvetrain thanks me for that .
Phil
Old Dec 26, 2005 | 06:27 PM
alpha's Avatar
Default Re: Rocker arms (hondaguyef)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaguyef &raquo;</TD></TR><TR><TD CLASS="quote">I check mine and if one looks like the pad is showing signs of wear I replace it. I run OE cams and don't rev high though so, my valvetrain thanks me for that .
Phil</TD></TR></TABLE>
Glad to hear I am not the only one checking mine I run aftermarket camshafts with large lobes and rev quite a bit higher
Old Dec 26, 2005 | 06:33 PM
SpeedDreamz.com's Avatar
I take a look at mine when I pull the head. I have never had an issue or noticed any excessive wear.
Old Dec 26, 2005 | 06:38 PM
hondaguyef's Avatar
Default Re: Rocker arms (SpeedDreamz.com)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpeedDreamz.com &raquo;</TD></TR><TR><TD CLASS="quote">I take a look at mine when I pull the head. I have never had an issue or noticed any excessive wear.</TD></TR></TABLE>
I've only had to change a few and they've all been on LS heads. Not sure if it's coincidental or not.
Phil
Old Dec 26, 2005 | 06:42 PM
Jared's Avatar
the ball mount rockers dont wear/handle high R abuse as well as the shaft mount rockers
Old Dec 26, 2005 | 07:28 PM
paulzy's Avatar
Default Re: Rocker arms (Jared)
quit talking about ***** and shafts
All the rockers I've encountered have been fine, but most of the heads I have don't see too much abuse except for a couple
Old Dec 26, 2005 | 07:57 PM
darrinbrewer's Avatar
Default Re: Rocker arms (paul vang)
my exhaust ones needed replaced, they were wore noticably, you could feel a slight sink, then back up at the shaft side.
they had 184k on them, the last 5k on sk2 stage2s, 25k before that ITRs, and all the other miles were stock gsr.
i replaced them with some 16k b16 units, hope i never have to buy another set, 150 almost per eachset from honda at discount. thats 1200 for all 8 sets
Old Dec 26, 2005 | 08:02 PM
alpha's Avatar
Default Re: Rocker arms (darrinbrewer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by darrinbrewer &raquo;</TD></TR><TR><TD CLASS="quote">my exhaust ones needed replaced, they were wore noticably, you could feel a slight sink, then back up at the shaft side.
i replaced them with some 16k b16 units, hope i never have to buy another set, 150 almost per eachset from honda at discount. thats 1200 for all 8 sets </TD></TR></TABLE>
Yep. Not cheap at all. Not fun to replace either.
Old Dec 27, 2005 | 07:18 AM
those were quit easy once the cams are out, took 10 minutes max. had to pull them once while still in the car to change LMA's one tme
alpha
Dec 26, 2005 09:22 PM
jdmcoop
15
Sep 8, 2005 03:40 PM
Mr_GaBIG
20
Dec 16, 2004 05:58 PM
drunknbass
Aug 1, 2004 09:52 PM
91integraLSVTEC
Sep 24, 2003 11:47 AM
