B18C6 + 97 EJ6 = Which AEM Intake (Short Ram)
Which intake should I use for a 1997 EJ6 with a 99 ITR in it? I have to use a short ram intake because there's no hole for the cold air intake. Or should I just get a cold air intake for a type r and just hack it up to fit? I haven't checked with any other manufacturers, but I kinda want to stick to the AEM joint. Thanks.
and here is a picture, if anyone cares...
It should slide right on. If you think about it logically, all you're looking for is a CAI that will work with a B series engine in a Civic and an Si came with one stock. Problem easily solved.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00Red_SiR »</TD></TR><TR><TD CLASS="quote">It should slide right on. If you think about it logically, all you're looking for is a CAI that will work with a B series engine in a Civic and an Si came with one stock. Problem easily solved.</TD></TR></TABLE>
Yep, and the Intake Manifold is in the same direction as the B16, it isn't like the stock GSR one that is retarded. Just buy an intake for an 99-00 civic Si.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by R33CIVIC »</TD></TR><TR><TD CLASS="quote">
Yep, and the Intake Manifold is in the same direction as the B16, it isn't like the stock GSR one that is retarded. Just buy an intake for an 99-00 civic Si.</TD></TR></TABLE>
That probably would be the best choice, but i think he's concerned with his HX as it doesn't have the hole going to the fenderwell like the ex's.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by powerBan.est1990 »</TD></TR><TR><TD CLASS="quote">
That probably would be the best choice, but i think he's concerned with his HX as it doesn't have the hole going to the fenderwell like the ex's.</TD></TR></TABLE>plasma cutter....problem solved
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by powerBan.est1990 »</TD></TR><TR><TD CLASS="quote">That probably would be the best choice, but i think he's concerned with his HX as it doesn't have the hole going to the fenderwell like the ex's.</TD></TR></TABLE>
yeah reading comprehension owns me!
but I would use a plasma cutter or something if you really want the cold air, personally I would get the short ram a cold air intake really ain't that much better and you will not have to worry about hydrolocking your motor. To me CAI are over-rated, I mean damn it is just an intake.
so basically if you want to get the CAI I would agree...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BrokeAssWhiteboy »</TD></TR><TR><TD CLASS="quote">plasma cutter....problem solved
Cap'N Chronic
18
Mar 27, 2011 11:04 AM
