extra sensor
Old Dec 6, 2004 | 09:21 AM
RACINTWEEK's Avatar
Default extra sensor
im doing the mpfi wiring on my 91 civic w/ LS engine
i noticed there is a sensor on the coolant flange on the side of the block and there wasnt one on my STD engine
1: do i need this sensor?
2: where does the harness have a connector for it?
Old Dec 6, 2004 | 09:23 AM
FalkenSiR's Avatar
Default Re: extra sensor (RACINTWEEK)
If it came with the engine you probably do need it. Just can't think of its name...
Old Dec 6, 2004 | 09:31 AM
RACINTWEEK's Avatar
Default Re: extra sensor (fast88std)
the engine came from a 92 so technically its OBD1 although i am staying OBD0
so i may not need this but i am trying to be sure before i break something
Old Dec 6, 2004 | 09:47 AM
Mr_CRX's Avatar
Thats the fan switch. You dont need to plug it in unless you want your radiator fan to turn on
It's just a standard 2-pin plug. If I remember correctly, theres a plug left over from the DPFI-MPFI swap that you can use.
Take the two wires that originally went to the back of the block (thats where the fan switches are on obd0), I believe they're black and yellow. Cut off the bullet ends on them, and solder on that 2-pin plug with enough wire to reach that new sensor.
The order of the wires doesnt matter. It's just a switch that connects the circuit of those two wires and turns the fan on.
Old Dec 6, 2004 | 10:42 AM
RACINTWEEK's Avatar
Default Re: extra sensor (Mr_CRX)
so i dont use either of the sensors on the back of the block?
Old Dec 6, 2004 | 11:58 AM
RACINTWEEK's Avatar
TTT
Old Dec 7, 2004 | 11:48 AM
RACINTWEEK's Avatar
bump
Old Dec 7, 2004 | 11:51 AM
EFSiR's Avatar
you should only have 1 next to the oil filter...
Old Dec 7, 2004 | 12:48 PM
RACINTWEEK's Avatar
Default Re: extra sensor (EFSiR)
ok i got it, im taking the 2 con from the plug on the left and wiring them to the sensor on the coolant flange
so simple...im a moron
teler86
22
Dec 27, 2012 11:31 AM
wallabee32
May 2, 2009 10:23 AM
1990hondaHF
15
Mar 6, 2007 12:29 PM
SaMMaE01
Nov 5, 2006 09:32 AM
VNTEC
Mar 15, 2004 04:50 PM
