why does my car run too rich?
Old Dec 5, 2004 | 08:14 PM
hondaeg8's Avatar
Default why does my car run too rich?
here's a vid of my car:
http://www.sporkperformance.co...e.AVI
notice all the black smoke out the exhaust. why does my car run rich most of the time? last night seemed like more than usual to me, but that is the really the first time i got to see it from behind since i'm always the run driving my car.
i have a kenji chipped P28 with the all motor program chip. could the chip be the reason why?
my friend said he sees the smoke come out when i hit vtec.
fuel pressure is set at 40psi.
my friend has the same ecu in his hatch with itr motor and his car doesn't throw that black smoke out when he hits vtec.
Old Dec 5, 2004 | 08:24 PM
99skunkedSi's Avatar
Default Re: why does my car run too rich? (hondaeg8)
maybe your rings are going
Old Dec 5, 2004 | 08:26 PM
hondaeg8's Avatar
Default Re: why does my car run too rich? (99skunkedSi)
hmmmm....i don't think so.
its not oil
Old Dec 5, 2004 | 08:49 PM
chris_m's Avatar
* B A N N E D *
Turn your pressure back to stock 38 psi and what is your ignition timing set at. Most basic chips will run rich on top end on simple set ups. What are your running?
Old Dec 5, 2004 | 08:52 PM
mtber's Avatar
What is the motor setup... include exact specs etc... Black smoke is normal if you are running rich & you don't have a cat :-)
Pull your plugs and check them, they are probably black.... hence a rich condition.
If you are running stock injectors, 48-52 psi at Wide Open Throttle is what your FPR should be at.
Old Dec 5, 2004 | 09:06 PM
hondaeg8's Avatar
Default Re: (mtber)
jdm gsr motor
jdm dc 4-1 header
cai
b16 tranny
2.5" exhaust piping
msd sci kit (for sale though)
aem fuel rail (for sale also)
apexi muffler
i have a resonator, no cat.
the have the fuel pressure at 39psi now.
Old Dec 5, 2004 | 09:11 PM
hondaeg8's Avatar
oh yeah...timing is up 2 degrees
Old Dec 6, 2004 | 11:52 PM
hondaeg8's Avatar
my friend thinks its becuause i have my timing advanced two degrees, but i don't think so
Old Dec 7, 2004 | 12:08 AM
chris_m's Avatar
* B A N N E D *
got any check engine codes
Old Dec 7, 2004 | 10:06 AM
hondaeg8's Avatar
Default Re: why does my car run too rich? (alld16a)
no
Old Dec 7, 2004 | 10:17 AM
johnzm's Avatar
your just running rich. the people that own and operate dyno's in your area will LOVE to help you out, they are real good at making that black smoke go away
jc2801
Aug 28, 2008 11:50 AM
crawlin
Jul 24, 2006 01:30 PM
Rob!
Jun 22, 2006 12:10 AM
ZoNe_HKS
Feb 11, 2003 06:52 PM
Pro-Lude
Sep 11, 2001 01:19 AM
