motor mount problems
Old Dec 5, 2004 | 06:39 PM
EKautox's Avatar
Default motor mount problems
Hey, sorry if this has been covered, but I couldn't find it in all the "motor mount" threads. How can you tell if you just need to replace the inserts, or the whole mount. Cuz I managed to find a curb and my front bumper found the wall, and now my mount is leaking REALLY bad. I am assuming I need to replace the entire thing, but I'm not sure cuz I dont know what caused it to break. I'm guessing the jolt of stopping so quick caused it, but again, I'm not sure. TIA.
Old Dec 5, 2004 | 07:11 PM
bgoetz's Avatar
Default Re: motor mount problems (EKautox)
what is it leaking????
Old Dec 5, 2004 | 07:37 PM
thruvines87's Avatar
how the hell does a motor mount leak? are u crazy?
Old Dec 5, 2004 | 07:38 PM
jlacoy82's Avatar
71.192.16.183
Default Re: motor mount problems (thruvines87)
They are fluid filled.
https://honda-tech.com/zerothread?id=541371
Old Dec 5, 2004 | 07:54 PM
Motorhead
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thruvines87 &raquo;</TD></TR><TR><TD CLASS="quote">how the hell does a motor mount leak? are u crazy?
The driver side stock mount is gell filled & no, he's not crazy. yet...
Old Dec 5, 2004 | 07:56 PM
Ricey McRicerton's Avatar
Default Re: motor mount problems (Motorhead)
I'm pretty damn sure you have to replace the whole mount if the fluid filled one pops.
EDIT: If you've ever seen motor mount inserts you'd understand. The ES inserts go inside the two lower torque mounts (right by the tires) and the rear mount.
Old Dec 5, 2004 | 08:06 PM
Default Re: motor mount problems (Ricey McRicerton)
o i c my bad guys. shutting up now!
Old Dec 5, 2004 | 09:04 PM
sohcisbest's Avatar
replace it, not worth hassle of doing twice
Old Dec 7, 2004 | 02:58 PM
EKautox's Avatar
Default Re: motor mount problems (sohcisbest)
Thanks for all the input, I definitely plan on replacing it, but I have a little dilemna: I have to drive home from San Diego to Sacramento (~500 miles), but I'm not sure if 1) I will have time or money to get a new one before I leave and 2) if I find one, I'm not sure if I will have time to install it because of finals. Do you guys think it's up to the drive if I replace it right after I arrive in Sac? Thanks.
Old Dec 9, 2004 | 01:26 AM
EKautox's Avatar
ttt
Hey guys, sorry to push the topic, but I REALLY need an answer ASAP. thanks.
Old Dec 9, 2004 | 02:23 AM
nub.96ek's Avatar
I wouldn't recomend driving on that mount. It's easy to swap though... put a jack under the oil pan and get a wrench.
bunske123
Oct 10, 2007 10:50 PM
D-meet07
Jul 15, 2007 12:23 PM
DeeCeeTwo
Jul 19, 2005 11:32 PM
Train
Jun 12, 2003 10:28 PM
Ideal
Aug 2, 2002 02:08 PM
