Coolant gauge not working after swap..fan not turning on
i did a d15b vtec swap this weekend and my wiring harness had some corrosion on it, the plug that goes on the side of the head that is just a one wire plug broke and fell on the ground with a bunch of other **** and i cant find it, is this the cooant temp sensor and the signal to turn on the fan???
yes it is the temp sender...no it does not turn on the fan. on your original engine the fan switch is on the back of the block with two bullet terminals..i believe the vtec engine the switch is on the t-stat housing with a different style connector small round two wire
Badway is right!! I just did a D15-b installation, and the connection for the fan is on the termostat housing. What I did is resodered the wires off my harness to the connector on the housing, and it worked perfect... Hope this helps..
hey the new engine did come with a connector on the tstat housing with a litttle bit of two wires coming off of it, how do i know which ones to connect where, on the old wires they are different colors
doesn't matter which goes where. the switch only closes the circuit ie:connects the wires together when the temp is up to turn on the fan
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HamiltonRex »</TD></TR><TR><TD CLASS="quote">my fan dosent come on, temp never goes up. Its also cold.
The one on the side of the head is for the indash gauge, the one on the back of the block is for ecu and/or fan</TD></TR></TABLE>
same here
same here
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BadWay »</TD></TR><TR><TD CLASS="quote">the temp guage sending unit is the single bullet connector on the head near the distributor. </TD></TR></TABLE>
and, the 2 wire connector on the end of the head is the coolant temp sensor for the ECU
b18cEK
29
Sep 13, 2009 03:04 PM
xdustin513x
Oct 14, 2008 12:01 PM
tibss
Jan 31, 2008 11:28 PM
Vtec's My Anti-Drug
Apr 22, 2007 04:00 PM
