B16a Stroker Motor
Old Jan 1, 2002 | 03:31 PM
89HF's Avatar
New User
Default B16a Stroker Motor
Will a B18c1(GSR)crank fit in a B16a block?What machine work has to be done,what pistons and rods will work?
Old Jan 1, 2002 | 06:26 PM
rainforest's Avatar
Default Re: B16a Stroker Motor (89crxb16a)
do this, todas stroker kit is only the 87mm crank with 134mm b16a rods with custom pistons iam sure they will sell just the stroker pistons.
Old Jan 1, 2002 | 06:47 PM
chad's Avatar
Moderator
contact dave at 843-760-4804 tell him chad sent you...he sell stroker kits!!
http://www.randdmotorsports.com
Old Jan 1, 2002 | 10:12 PM
HotRodTeg's Avatar
Default Re: B16a Stroker Motor (chad)
Yes this will work but The rod journals on the b18c1 crank is thinner then the b16 crank, so you would have to use a b18c rod and have a coustom piston made Where the wristpin on the piston is moved up how ever mm u need. I asked JE if they would do that and they said just give them the specs and they will make anything
executedace
Jun 5, 2010 11:27 PM
chuisek9
Apr 15, 2008 06:08 PM
d'hondaho
Feb 28, 2008 07:12 AM
skribblah
Apr 29, 2003 06:51 PM
BoostedSi
Apr 25, 2002 01:50 PM
