B16b and spoon stroker
Old Dec 5, 2004 | 11:19 AM
lonely superstar's Avatar
Default B16b and spoon stroker
was wondering if anyone on has installed,or know someone who has,a spoon stroker kit on a B16b.if so what kind of numbers could i expect,and is the stock ecu up to the task? any HELP would be greatly appreciated. thanks
Old Dec 5, 2004 | 11:41 AM
emotionisdead's Avatar
Very Emergency!!
Default Re: B16b and spoon stroker (lonely superstar)
my friend just got one for his b16b. all the stoker kit does is make the b16b into a b18c type r motor. the b16b and b18c share the same block. the noraml b16a has a deck hieght or 7mm shorter than the b16b. you could probably expect similar numbers to that of a jdm b18c R motor. you gain a little hp, but you gain quite a bit of torque. is your b1b stock? if so it would probably would but out a little better numbers than a stock b18c because of the ctr intake cam is slightly bigger.
Old Dec 5, 2004 | 11:53 AM
thank you yes it is completley stock,and i want to keep it as factory as possible.will the stock ecu be up to the task?
Old Dec 5, 2004 | 12:12 PM
anyone else?
Old Dec 5, 2004 | 12:23 PM
Mr.OB*GYN_Rhett's Avatar
yeah do it, its only like 1k or so right? you ecu should be fine for the time being, would get in for some tuning though
Old Dec 5, 2004 | 12:28 PM
Default Re: B16b and spoon stroker (EkNineSpooner)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EkNineSpooner &raquo;</TD></TR><TR><TD CLASS="quote">yeah do it, its only like 1k or so right? you ecu should be fine for the time being, would get in for some tuning though </TD></TR></TABLE>
yea,i am gonna do it,i think the kit is around $1100 shipped.definatley will be doing some tuning.anyone else have some experience with it? and thanks for your replies
Tony8174
Sep 22, 2012 10:27 PM
bsm123
Engine Management and Tuning
19
Jun 3, 2011 09:33 PM
B18C Hatch
Sep 23, 2003 06:07 PM
ek9lau
May 13, 2003 01:58 PM
