Question on mini me swap
I"m doing a mini me swap in a 91 civic.It's a built A6 block from a 91 si and a Y8 head.The A6 bock doesn't have a knock sensor,so what should i do in order to run the Vtec?I have the conversion harness for obd 0-obd 1 in order to run the p28,but will i be better off with a ls ecu and a rpm switch.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSVTEC 91 Civic »</TD></TR><TR><TD CLASS="quote">I'd get a VTEC ECU...</TD></TR></TABLE>
Yeah.. It makes everything seem like it was meant to be..
Getting a Vtec ecu is not a problem.I'm tring to find out if it will be ok to run the p28 with out a knock sensor,or go with a rpm switch.
