Results of my compression test. How do these numbers measure up
Old Jan 1, 2002 | 02:45 PM
S&P500ITR's Avatar
New User
Default Results of my compression test. How do these numbers measure up
Just wondering if these numbers seem about right for compression around 11.2:1?
I was bored so I took pics.
[Modified by S&P500ITR, 3:49 PM 1/1/2002]
Old Jan 1, 2002 | 03:19 PM
sgT's Avatar
sgT
Default Re: Results of my compression test. How do these numbers measure up (S&P500ITR)
Looks good.
Old Jan 1, 2002 | 03:20 PM
JPP's Avatar
JPP
That's seem good. That last picture is probably from piston #4 (next to the distributor), mine is also +- 10 psi higher them the rest. How did you do the test? (open throttle?, how many cranks?)
Old Jan 1, 2002 | 03:39 PM
kenji's Avatar
25 Year Member
Default Re: Results of my compression test. How do these numbers measure up (JPP)
Dustin,
Those numbers look real nice.
-kenji
Old Jan 1, 2002 | 03:40 PM
EleanoR's Avatar
Default Re: Results of my compression test. How do these numbers measure up (kenji)
Dang Dustin you must of been bored!
Later,
Mike
Old Jan 1, 2002 | 03:52 PM
Trey's Avatar
25 Year Member
Default Re: Results of my compression test. How do these numbers measure up (talkie25)
Those numbers look very good. I just had the bottom end rebuilt on my B18c1 and my numbers are 209, 209, 210, 220 with JDM ITR pistons. I was a lil dissappointed. But I didn't floor the accelerator. Why do you have to do a compression check with the throttle open? Would that raise my numbers a lil?
Old Jan 1, 2002 | 04:03 PM
S&P500ITR's Avatar
New User
Default Re: Results of my compression test. How do these numbers measure up (Trey)
I don't know if I was doing it right, but I was at WOT and turned the key for a 5 count (or so). I kept the car in the on position the entire time, all plugs were removed, and injectors were unplugged.
If you thought I was bored taking the above pics, you are going to laugh because I decided to take pics of all my plugs also.
The plugs are out of my car running a skunk ecu
1.
2.
3.
4.
ld plug before bumped compression and skunk ecu
[Modified by S&P500ITR, 5:31 PM 1/1/2002]
Old Jan 1, 2002 | 04:11 PM
primoEF's Avatar
I think the best to check is keep the battery charging during the test, take out all the spark plugs, fuse of the fuel pump, floor the thorttle and then crank.
Old Jan 1, 2002 | 04:19 PM
JPP's Avatar
JPP
The open throttle is to make sure you bring as much air as possible to the pistons. It is suppose to give you higher readings. Just make sure to disconnect the injectors before you do it, so you don't flood the engine.
Old Jan 1, 2002 | 04:55 PM
DB2-R81's Avatar
25 Year Member
Hey, put some never seize on your plug threads, I can see the Aluminium flecks from your cylinder head.
Old Jan 1, 2002 | 06:42 PM
Mike K's Avatar
Default Re: Results of my compression test. How do these numbers measure up (DB1-R81)
Dustin, looks good. plugs do too.
Old Jan 1, 2002 | 08:46 PM
DR. ON POINT's Avatar
Banned
Default Re: Results of my compression test. How do these numbers measure up (Mike K)
its good
xd69
Mar 7, 2006 12:10 PM
InLimbo87
Jun 22, 2004 07:54 PM
gsrvx
Nov 21, 2002 03:54 PM
Norcalstoppy
Nov 21, 2002 12:55 PM
gsrvx
Jun 27, 2002 07:18 PM
