Best 6th gen brake pads with least dust and extended rotor life.
About to change brake pads on the accord. not needing race/track pads. just no dust, long life, more rotor life.
thanks in advance.
thanks in advance.
just get some good tools. there isnt much to the job at all. take the wheel off, take a few bolts off. or you could get a book from http://www.helminc.com which has the torque specs and step by step. for brakes---unless for race apps., just make sure its all tight. also, get some anti-sieze.
thx.
how are they on dust? average?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by v4lu3s »</TD></TR><TR><TD CLASS="quote">id stick with oem honda pads</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by manmanSS »</TD></TR><TR><TD CLASS="quote">is there a DIY on chaning rotors anywhere...I need to do it but dont know how to</TD></TR></TABLE>
if you have a 6th gen, mine are press on, the rotors arent just bolted on. what model do you have
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ericjackson »</TD></TR><TR><TD CLASS="quote">
if you have a 6th gen, mine are press on, the rotors arent just bolted on. what model do you have</TD></TR></TABLE>
i have a 6th gen--new to me though. didnt know they were press on. never thought honda would make a car with much challenge. dont need to remove rotors to change pads i hope. couldnt see any reason for it at all.
What? There are two screws holding my rotor down on my 6th gen. Secondly, I could probably drive around without those two screws, because the calipers, but more so the rim torqued down with four lug nuts are holding everything in place.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by -Bionic- »</TD></TR><TR><TD CLASS="quote">
What? There are two screws holding my rotor down on my 6th gen. Secondly, I could probably drive around without those two screws, because the calipers, but more so the rim torqued down with four lug nuts are holding everything in place.</TD></TR></TABLE>
well on my 98 coupe lx. front rotors are press on. maybe they made mine differently than everyone else's...
My 98 coupe ex is held in place with two screws (which you don't need). 6th gens are not pressed on, nor are they hub-on-rotor design. very easy to change.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18crx »</TD></TR><TR><TD CLASS="quote">thx.
very, very minimal dust, which is the reason i continue to use OEM pads. i've used other "cheap" brands and simply couldn't stand the brake dust and squealing.
I have doubts that yours are press-on. What is press-on? Do they come in different colors? Will the chip if I type too hard?
</TD></TR></TABLE>I have doubts that yours are press-on. What is press-on? Do they come in different colors? Will the chip if I type too hard?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philadd »</TD></TR><TR><TD CLASS="quote">
very, very minimal dust, which is the reason i continue to use OEM pads. i've used other "cheap" brands and simply couldn't stand the brake dust and squealing.</TD></TR></TABLE>
thx. super helpful.
thx. super helpful.
ericjackson
You are pressed on.
</TD></TR></TABLE>ericjackson
You are pressed on.
I can get you a deal on them. Cost plus $5.00 plus shipping
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HONDAofPOKY »</TD></TR><TR><TD CLASS="quote">
I can get you a deal on them. Cost plus $5.00 plus shipping</TD></TR></TABLE>
pm sent
pm sent
ok. i hate to bring up old topics. i said mine were press on, everyone else said that they had bolts in them, so i finally took pics
BTW, sorry about the rust look. i was in the middle of sanding and painting them.
Modified by ericjackson at 11:05 PM 12/21/2004
i recomend honda pads....they work the best..and honda stock rotors..aftermarket cheap pads no good...they give u brake dust and squeaks...youll hate it if u the picky type...stick with honda pads bro and youll be aight
