Daily driven 250 NA whp. How do I get it?
Old Dec 5, 2004 | 01:36 AM
Boarderx192's Avatar
Default Daily driven 250 NA whp. How do I get it?
How to I acchieve this goal. I have a JDM H22A with a port and polish, Crower springs and retainers, lightend flywheel with a Centerforce dual friction clutch, intake, exhaust, and riced out header. I know I need cams but dont know what kind to get. was thinking Crower stage 2's. What should I get to reach my goal and make it streetable.
Old Dec 5, 2004 | 01:50 AM
bad-monkey's Avatar
Default Re: Daily driven 250 NA whp. How do I get it? (Boarderx192)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boarderx192 &raquo;</TD></TR><TR><TD CLASS="quote">How to I acchieve this goal. I have a JDM H22A with a port and polish, Crower springs and retainers, lightend flywheel with a Centerforce dual friction clutch, intake, exhaust, and riced out header. I know I need cams but dont know what kind to get. was thinking Crower stage 2's. What should I get to reach my goal and make it streetable.</TD></TR></TABLE>
not alot of 250 whp NA h22's out there. Are there even any? the highest i've seen is ~240 whp and i believe it was on 100+ octane.
to get 250 you're going to have to up your cr. crower stage 2's sound appropriate. need a new header assuming your riced out one is a DC/DC copy. ITB's. pullies would help. one hell of an engine management system, and an even more amazing tuner.
Old Dec 5, 2004 | 04:32 AM
TypeR0207's Avatar
Default Re: Daily driven 250 NA whp. How do I get it? (bad-monkey)
You'll never get 250 "daily driven" out of an H22 all motor. Track car, maybe.
You're talking 12+ compression, at least Crower Stage 3's or custom grinds, 8,500 rpms, totally built bottom end with a little more displacement. ITB's, stand alone fuel management, etc.
A few years ago, Mark Brauning was at around 260 in his fully built race motor.
Expect to spend upwards of $10,000 on just the motor when all is said and done.
Old Dec 5, 2004 | 05:30 AM
delslowh23's Avatar
Default Re: Daily driven 250 NA whp. How do I get it? (TypeR0207)
lots of $ https://honda-tech.com/zerothread?id=1010457
Old Dec 5, 2004 | 07:57 AM
hOndafienD 04's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TypeR0207 &raquo;</TD></TR><TR><TD CLASS="quote">Expect to spend upwards of $10,000 on just the motor when all is said and done.</TD></TR></TABLE>
umm not if he goes forced induction route.
Old Dec 5, 2004 | 08:26 AM
A Blue Lude's Avatar
Default Re: Daily driven 250 NA whp. How do I get it? (hOndafienD 04)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hOndafienD 04 &raquo;</TD></TR><TR><TD CLASS="quote">umm not if he goes forced induction route. </TD></TR></TABLE>
FI is not NA, though. With a turbo, everything changes....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boarderx192 &raquo;</TD></TR><TR><TD CLASS="quote">Daily driven 250 NA whp. How do I get it?</TD></TR></TABLE>
Old Dec 5, 2004 | 08:52 AM
ohh i missed the NA part...then hes crazy....hes never gonna get it, and have it be sreetable.
Old Dec 5, 2004 | 08:53 AM
BrokeLude's Avatar
Probably wouldn't be hard if you consider nitrous. You could have a daily driver in the high 100s, and then get your 250+ when you crack open the bottle.
Old Dec 5, 2004 | 09:17 AM
2point6's Avatar
Default Re: Daily driven 250 NA whp. How do I get it? (BrokeLude)
I had to step in here, because there is a bunch of BS being spread. 250whp is attainable, streetable, reliable, and able to be driven on 91 octane. I do it daily. It does cost a bit, but any h22 build (if done right) costs...
Too bad that Endyne engine was only pulling 228+ whp on a dynojet and blew shortly after.
Old Dec 5, 2004 | 09:53 AM
it can be done, and it could be reliable, but it would have to be really great tuned! its still a hard task.
Old Dec 5, 2004 | 11:12 AM
SpeedMachine's Avatar
Default Re: (hOndafienD 04)
id like to see what he would run
Old Dec 5, 2004 | 11:18 AM
prylwd's Avatar
It will be extremely hard and expensive. I think you should go for it. Start by doing a lot of research. Who will be doing the work? Get a better header like prospeed or smsp.
Old Dec 5, 2004 | 12:30 PM
jdmcivicferio's Avatar
Default Re: (prylwd)
lol, you guys think it is that hard to get 250whp out of a 2.2L? I made 200whp in mine with just a intake/header/chip/fpr/throttle body and free port matching, never even took off the valve cover. Another guy that circuit races his car at the dyno I go to made 240whp with a fast standalone, cams/ported head, valves springs retainers and other misc bolt ons, he still had a BONE stock 2.2L bottem end. I think you can make up to a 260-270hp N/A h22 easily
Old Dec 5, 2004 | 01:38 PM
md23vtec's Avatar
Default Re: (jdmcivicferio)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmcivicferio &raquo;</TD></TR><TR><TD CLASS="quote">lol, you guys think it is that hard to get 250whp out of a 2.2L? I made 200whp in mine with just a intake/header/chip/fpr/throttle body and free port matching, never even took off the valve cover. Another guy that circuit races his car at the dyno I go to made 240whp with a fast standalone, cams/ported head, valves springs retainers and other misc bolt ons, he still had a BONE stock 2.2L bottem end. I think you can make up to a 260-270hp N/A h22 easily </TD></TR></TABLE>
I dont know about easily but yes it can be done ,
Old Dec 5, 2004 | 02:01 PM
bb6h22a's Avatar
You sell all that **** and buy a real sports car, or your set realistic goals; a 250 hp NA motor won't "streetable" much less tolerable to drive on a daily basis. Instead of making power, why don't you make your car lighter; same net effect (eg, better power to weight ratio) without creating a nightmare situation with respect to reliability.
Old Dec 5, 2004 | 02:14 PM
Mr.Dew's Avatar
Yep, it's Eric.
NOS is cheating
But i think 200whp is very realistic like civicferio was saying.. you don't even need to take off the valve cover to do that. i would say 230whp is a more realistic goal unless you want big time expenses.
Old Dec 5, 2004 | 03:38 PM
bad-monkey's Avatar
it's not impossible to get 250 whp on a 2.2L engine, but i wouldn't call it easy. if it was, don't you think we'd all have 270 whp NA ludes?
putting down 200 whp is one thing. 270 is a lot more money and effort. law of diminishing returns.
not busting your *****, but what would be your blueprint for a 270 whp lude?
i'm thinking it'd look alot like:
12.5:1 cr
ITB's
I/H/E/P/Test pipe
crower stage 3's
Standalone like AEM/Motec
full engine balancing
that's 10,000 dollars of work right there, if not more.
Old Dec 5, 2004 | 04:52 PM
h22a193's Avatar
Default Re: (bad-monkey)
ANYTHING can be done with anough green.....
Old Dec 5, 2004 | 08:07 PM
Default Re: (h22a193)
I am planning on getting crower stage 2's and looking into ITB's and an standalone fuel management system. I want to keep my bottem end stock. If 240 hp is more realistic, thats fine. I want to get colse to the 250 mark without sleeving my block and putting in different pistons.
Old Dec 5, 2004 | 09:30 PM
00LudeLover's Avatar
Default Re: (Boarderx192)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">I want to get colse to the 250 mark without sleeving my block and putting in different pistons. </TD></TR></TABLE>
have fun getting maybe 220 then.
or...more, but then your engine going to hell shortly after.
Old Dec 5, 2004 | 09:41 PM
2point6's Avatar
Default Re: Daily driven 250 NA whp. How do I get it? (bb6h22a)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bb6h22a &raquo;</TD></TR><TR><TD CLASS="quote">
Tell me why not? Mine is... No offense but don't talk unless you have done it. I hate people giving missinformation based on hearsay. "Experience makes the man."
Old Dec 5, 2004 | 09:54 PM
Default Re: Daily driven 250 NA whp. How do I get it? (2point6)
Why do you say that the motor will go to hell shortly there after? Has yours done it? Or are you just going by hear-say?
Old Dec 5, 2004 | 10:04 PM
2point6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boarderx192 &raquo;</TD></TR><TR><TD CLASS="quote">Why do you say that the motor will go to hell shortly there after? Has yours done it? Or are you just going by hear-say?</TD></TR></TABLE>
Are you asking me? My engine is fine. Thanks
Old Dec 5, 2004 | 10:09 PM
SuperSlow's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2point6 &raquo;</TD></TR><TR><TD CLASS="quote">
Are you asking me? My engine is fine. Thanks </TD></TR></TABLE>
I think he was talking to 00ludelover.
Your motor is one of a kind anyway.
Old Dec 5, 2004 | 10:17 PM
2point6's Avatar
Default Re: Daily driven 250 NA whp. How do I get it? (SuperSlow)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SuperSlow &raquo;</TD></TR><TR><TD CLASS="quote">
Your motor is one of a kind anyway.</TD></TR></TABLE>
SO YOU ARE CALLING ME A FREAK? lol.
