ABS Plastic - Best Way to Cut? for my EJ8
Old Dec 4, 2004 | 06:39 PM
SRCivic97's Avatar
Default ABS Plastic - Best Way to Cut? for my EJ8
I'm doing some gauge fabrication, looking for the best way to cut ABS plastic. Simple question I'm sure. Any suggestions??
Old Dec 4, 2004 | 06:46 PM
Vero's Avatar
dremel cut off wheel for straight cuts. Use the highest RPM and go very slowly, make hashed cuts first along the to-be-cut area. Also use both hands to hold it still.
This is a minimal mess approach.
For rounded shapes, like guages, cut the square out first, then go back with the sanding bit and sand down the very last pieces to the shape needed.
Dremels are amazing. ACE Hardware has a sale on the 7.2 cordless for $35, comes with 52 accessorie pieces.
Great buy for the tool.
Old Dec 4, 2004 | 06:50 PM
SRCivic97's Avatar
Default Re: (Vero)
I was just going to say - **** I don't own one That's cool though I will probably invest in one or else rent one from home depot danke-
Old Dec 4, 2004 | 06:52 PM
Joon Joon's Avatar
a dremel is ur friend.. u could do light port matching with it if u'd like.. u could use it to polish ur wheels.. and kragen got a dremel set for 7 bucks gotta pick one up for myself
Old Dec 4, 2004 | 06:56 PM
Vero's Avatar
Its a must have tool for DIY car mods. It can get in into tight areas and can use vitually any tool.
-I used it to cut the bolts of my exhaust when I did that.
-Used it to drill small holes for wiring.
-Used it to polish my valve cover
-Used it to grind down small pieces for fitment.
-Used it to sheetrock my porch, cutting outlet holes.
I personally like the corded ones because they have more power and variability. You can get those for $50-60 with some great features. Definatly a great holiday gift.
Old Dec 4, 2004 | 06:58 PM
SRCivic97's Avatar
Default Re: (Vero)
How long did your valve cover take? Sounds like a great idea
raverx3m
Apr 8, 2016 10:53 AM
get RIGHT
Suspension & Brakes
Jun 23, 2009 11:59 PM
jmai86
Jul 2, 2007 01:29 AM
SRCivic97
Welding / Fabrication
Dec 4, 2004 06:55 PM
yellow blur
Jan 28, 2003 09:42 AM
