ABS Plastic - Best Way to Cut? for my EJ8
I'm doing some gauge fabrication, looking for the best way to cut ABS plastic. Simple question I'm sure. Any suggestions??
dremel cut off wheel for straight cuts. Use the highest RPM and go very slowly, make hashed cuts first along the to-be-cut area. Also use both hands to hold it still.
This is a minimal mess approach.
For rounded shapes, like guages, cut the square out first, then go back with the sanding bit and sand down the very last pieces to the shape needed.
Dremels are amazing. ACE Hardware has a sale on the 7.2 cordless for $35, comes with 52 accessorie pieces.
Great buy for the tool.
Re: (Vero)
I was just going to say - **** I don't own one That's cool though I will probably invest in one or else rent one from home depot danke-
Its a must have tool for DIY car mods. It can get in into tight areas and can use vitually any tool.
-I used it to cut the bolts of my exhaust when I did that.
-Used it to drill small holes for wiring.
-Used it to polish my valve cover
-Used it to grind down small pieces for fitment.
-Used it to sheetrock my porch, cutting outlet holes.
I personally like the corded ones because they have more power and variability. You can get those for $50-60 with some great features. Definatly a great holiday gift.
get RIGHT
Suspension & Brakes
06-23-2009 11:59 PM
