short throw question
Old Dec 4, 2004 | 04:56 PM
stivic's Avatar
Default short throw question
I have a 94 civic with a GSR swap Im ordering a short throw shifter but im not sure which one to get theres 92-95 civic ones and 94-01 integra ones my shift linkage is a B series so im guessing the civic shifters wont work???
Old Dec 4, 2004 | 05:06 PM
chinaski's Avatar
Default Re: short throw question (stivic)
if your using the tranny and shift linkage from the GSR swap, i would assume you would use a short shifter for a GSR.
Old Dec 4, 2004 | 10:03 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: short throw question (GeeSeR96)
They will both fit the same. Most short shifters have a narrow bottom piece that will fit either Civics or Integras (vs. the wider bottom piece on stock Integra shifters). For Integras you just add spacers. They'll both fit the same, it's just a preference of whether you want the shifter leaning back in neutral (Civic) or straight up in neutral (Integra, and my preference).
Just make sure you use an Integra linkage, otherwise it will look like you're in 3rd when it's actually in neutral (shifter leans forward ).
Old Dec 5, 2004 | 02:29 AM
s2kkid's Avatar
Default Re: short throw question (PatrickGSR94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 &raquo;</TD></TR><TR><TD CLASS="quote">They will both fit the same. Most short shifters have a narrow bottom piece that will fit either Civics or Integras (vs. the wider bottom piece on stock Integra shifters). For Integras you just add spacers. They'll both fit the same, it's just a preference of whether you want the shifter leaning back in neutral (Civic) or straight up in neutral (Integra, and my preference).
Just make sure you use an Integra linkage, otherwise it will look like you're in 3rd when it's actually in neutral (shifter leans forward ).</TD></TR></TABLE>
While were on this topic Ive noticed in the past youve got some knowledge on short shifters.
I bought the car used and I have no idea if the Shifter is shorter, or if its stock, Is there anyway I can tell this?
It does have a gunmetal skunk 2 **** on it, Which i had to modify like others to get the numbers to line up...
Old Dec 5, 2004 | 04:31 AM
LittleJohn1080's Avatar
do you have any pictures. imo the integra style shifter is my favorite i have a teg and love the stock shifter.
Old Dec 5, 2004 | 05:59 AM
LSvtec03's Avatar
Default Re: short throw question (vtecluder97)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecluder97 &raquo;</TD></TR><TR><TD CLASS="quote">While were on this topic Ive noticed in the past youve got some knowledge on short shifters.
I bought the car used and I have no idea if the Shifter is shorter, or if its stock, Is there anyway I can tell this?</TD></TR></TABLE>
several ways to tell...
if you can look at your shifter, a stock shifter is black, with thick welds that are probably a little rusty.
the length of the shifter between the pivot (ball) and the bearing (cylinder welded on the bottom) is a little over an inch. a short shifter will be longer.
a short shifter is usually not black, but a color like silver, blue, red, and probably very shiny.
a short shifter will most likely not have any visible welds.
happened to have my stock shifter handy. hth
tinctorus
Nov 19, 2010 09:49 AM
THEDirtyDseriesWOOT
Apr 26, 2007 08:56 PM
GapxGuy
Oct 4, 2002 05:14 PM
JICsube
May 30, 2002 04:16 AM
98coupe
Mar 3, 2002 09:50 PM
