Stock lugs on Millenia Wheels, compatability?
Old Dec 4, 2004 | 03:28 PM
Utilitarian's Avatar
Default Stock lugs on Millenia Wheels, compatability?
Anybody know whether stock lug nuts will suffice on Millenia wheels?
thanks!
-matt
Old Dec 4, 2004 | 04:18 PM
ebelp's Avatar
Default Re: Stock lugs on Millenia Wheels, compatability? (Utilitarian)
Why wouldn't they?
Old Dec 4, 2004 | 04:22 PM
Chris F's Avatar
Default Re: Stock lugs on Millenia Wheels, compatability? (ebelp)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ebelp &raquo;</TD></TR><TR><TD CLASS="quote">Why wouldn't they?</TD></TR></TABLE>
Concical vs. Ball, etc.
I don't have an answer for you though.
http://www.tirerack.com/wheels...s.htm
Old Dec 4, 2004 | 04:27 PM
Chris F's Avatar
Default Re: Stock lugs on Millenia Wheels, compatability? (ccfries)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ccfries &raquo;</TD></TR><TR><TD CLASS="quote">
All the aftermarket ones I've seen are Conical, the stock R ones are Ball. You're not supposed to mix&match, some crap about not making enough contact with the wheel to hold it well.
-Chris
ebelp's Avatar
I know the difference between conical and ball. I meant that stock Honda lugs shouldn't be any different from stock Mazda lugs, so they should work.
Old Dec 4, 2004 | 04:29 PM
Chris F's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ebelp &raquo;</TD></TR><TR><TD CLASS="quote">I know the difference between conical and ball. I meant that stock Honda lugs shouldn't be any different from stock Mazda lugs, so they should work. </TD></TR></TABLE>
Derp! *hits self on head*
-Chris
Old Dec 4, 2004 | 04:39 PM
Chris F's Avatar
http://www.geocities.com/typer_801/wheels.htm
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">Also know, you'll need traditional conical (60 deg.) taper lug nuts for the Mazda Wheels as the taper is different from the Type R wheel. If you can get the ones that came with the wheels those will work just fine, otherwise visit your local autoparts store and pick up a set or visit Mackin Industries and purchase a set online (12x1.5mm (not 1.25mm as previously stated), 3/4in(19mm) Open Bulge or Open Acorn will work great).</TD></TR></TABLE>
Old Dec 4, 2004 | 05:06 PM
Any definites?
Old Dec 4, 2004 | 05:08 PM
KOALA YUMMIES's Avatar
Call a Mazda service department?
Old Dec 4, 2004 | 06:15 PM
fullraceacura's Avatar
dam, i never knewthe lug nuts matterd... does anybody know which type of lug nuts volk wheels take? and what kind of lugnuts spoon's are?
Old Dec 4, 2004 | 06:50 PM
dFreezy's Avatar
Default Re: Stock lugs on Millenia Wheels, compatability? (itr#xxxxlives)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr#xxxxlives &raquo;</TD></TR><TR><TD CLASS="quote">does anybody know which type of lug nuts volk wheels take?</TD></TR></TABLE>they only look proper with the ray's nuts
PrimeElement
Oct 11, 2007 10:35 AM
TBmotorworx
Feb 12, 2006 05:36 PM
Toldge
Oct 28, 2005 10:04 PM
psilo
Nov 24, 2004 06:34 PM
es_squared
Oct 5, 2004 07:26 PM
