EF with OBD1 Dizzy write up...
I have both pics. of the ignition wiring diagrams from a 91 HF and a 92 GSR. I just want to simplify the need to look for a write up about this type of instalation.
This way if you want to run an OBD1 dizzy in your EF you'll have no problems.
Here's the info.
OBD1 schematic......................................... ......OBD0 schematic:
BLK/YEL= ignition switch....................................Same colors
YEL/GRN= ECU............................................... ..WHT
BLU= Tachometer........................................ .....Same color
WHT=TDC/CRANK/CYL sensor input...................BLU/YEL
ORN= TDC/CRANK/CYL sensor output................BLU/GRN
BLU/YEL= Crank input.......................................WHT
BLU/GRN= Crank output....................................ORN
WHT/BLU= TDC input........................................Same colors
ORN/BLU= TDC output......................................Same colors
Hope this helps...
"ALL DATA" info.
Can we make this a sticky???
Here's the info.
Hope this helps...
"ALL DATA" info.
you know what i heard is that you match up like colors, you need to switch wht, orn, bul/yel, and blu/grn to match each other.
you match up like colors, i also heard you will get a code 4 if you run a obd1 dist with your obd0 ecu
This does not work with all OBD0-1 conversion harnesses. This only works on harnesses that are built function for function. Also, this is only for OEM distributors. Distributor king distributors and some non-OEM distributors do not always have the same colors.
bringing this back from the dead. i want to know if this will work or not? anyone try it besides this guy?
dont want to go through all the work and it not funtion right.
Man... This is a useless thread! Can someone lock this please!
There are too many factors here... As Jason said(blown90) there are too many issues to say this.
1) you must have a obd1 ecu (the rotations on a obd0 ecu are different)
2) the ecu jumper must be a http://www.rywire.com style
3) the dizzy must be OEM HONDA, not aftermarket
Then yes, color to color will work
There is just too much misinfo going around to say that there is only 1 way to make it work.
Ryan
Ryan
sikcrx80
May 19, 2007 05:31 PM
