Bwahahahahahaha--Shock/Spring installation quote!
Old Dec 4, 2004 | 06:12 AM
Hazem's Avatar
Default Bwahahahahahaha--Shock/Spring installation quote!
650 for LABOR. That's right, nothing but LABOR, no parts. The guy said well you're looking at three and a half hours per axle. so that's 7 hours, plus 80 for alignment. I was like wtf he's like installing those on a civic isn't childsplay...
Is this normal??
if it is
Old Dec 4, 2004 | 06:19 AM
RedRebel's Avatar
Default Re: Bwahahahahahaha--Shock/Spring installation quote! (Hazem)
DIY
Old Dec 4, 2004 | 06:22 AM
Hazem's Avatar
Default Re: Bwahahahahahaha--Shock/Spring installation quote! (RedRebel)
If I DIY do I have to buy a camber kit? Or when I take it in for alignment can they do it without?
Old Dec 4, 2004 | 06:25 AM
RedRebel's Avatar
I think it depends on the amount of drop.
Old Dec 4, 2004 | 06:39 AM
CivicSiRracer69's Avatar
wow my motor would be runniung by now if I charged all my friends a 1/4 of that. I do it for Corona
Old Dec 4, 2004 | 06:45 AM
jlacoy82's Avatar
71.192.16.183
Personally, I think if you did it yourself, EVEN if it ended up costing you the entire day to get it complete, wouldnt it be that much more satisfactory? Not to mention the fact you didnt spend 700 dollars to have some ******** down at a garage to do the exact same thing you just did yourself?
Do a search for installing springs or shocks, and you'll see how its done, plenty of info.
Old Dec 4, 2004 | 06:47 AM
Luserkid's Avatar
Default Re: Bwahahahahahaha--Shock/Spring installation quote! (jlacoy82)
650 is way to much, i only charge 100 for springs.
Its a really easy job though, provided you have tools. If you dont have tools then i would recommend taking it to a shop.
Old Dec 4, 2004 | 06:49 AM
Hazem's Avatar
Default Re: Bwahahahahahaha--Shock/Spring installation quote! (Luserkid)
I guess some guys are comin down from kc for like 20 bucks, pizza, and some drinks. Do I have to get it aligned with a camber kit???
Old Dec 4, 2004 | 06:50 AM
Luserkid's Avatar
How much is your drop? (height wise)
If its more then 2 inches i would get a camber kit, if not then no worries.
Old Dec 4, 2004 | 06:53 AM
93CivicSI's Avatar
give us his phone number so we can all call and ask him for quotes.... - I did my whole car (93 Civic Si) in four hours including replacing ALL of the Rear LCA bolts after two (typical) broke off....
I say DIY
Nuespeed Koni Yellows and Eibach Pro Kits.....
Old Dec 4, 2004 | 06:55 AM
Br1anPham's Avatar
Default Re: Bwahahahahahaha--Shock/Spring installation quote! (CivicSiRracer69)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CivicSiRracer69 &raquo;</TD></TR><TR><TD CLASS="quote">wow my motor would be runniung by now if I charged all my friends a 1/4 of that. I do it for Corona </TD></TR></TABLE>
How about you fix my motor for me? cam broke and messed up my valves. Relace my cam and valves, I'll give you 2 (Two, not one) Corona. Ejay alway's gots them deals.
Old Dec 4, 2004 | 07:43 AM
.Noah Fecks's Avatar
Default Re: Bwahahahahahaha--Shock/Spring installation quote! (Br1anPham)
damn. drive to tn ill do it for a case of beer
Old Dec 4, 2004 | 08:49 AM
Nyceguy17's Avatar
Default Re: Bwahahahahahaha--Shock/Spring installation quote! (Noah *****)
Dude, you need to go back to that shop and tell him your girlfriend installed your stuff for free, and it only took her 2 hours total to do it. And tell him she's 16!!!
Old Dec 4, 2004 | 09:15 AM
vtecpoweredsol's Avatar
Default Re: Bwahahahahahaha--Shock/Spring installation quote! (Nyceguy17)
shops are usually bitches, this shop here wanted to charge my friend 350 to install his lowering springs on his srt-4
Old Dec 4, 2004 | 09:18 AM
Nyceguy17's Avatar
Default Re: Bwahahahahahaha--Shock/Spring installation quote! (vtecpoweredsol)
Algunas de estas tiendas deben pensar que somos ******** estúpidos. Si alguien me intentó al overchage para algo de ése mucho, ¡me cercioraría de que el resto de la ciudad supiera cuáles era un
butthole este individuo!
Old Dec 4, 2004 | 09:52 AM
sohcvtec1995's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid &raquo;</TD></TR><TR><TD CLASS="quote">650 is way to much, i only charge 100 for springs.
Its a really easy job though, provided you have tools. If you dont have tools then i would recommend taking it to a shop. </TD></TR></TABLE>
Word. Most shops do it for that much around here. There is no way any Shop should charge more then 150 for all four. ANd then a Alighnment.
JeffS's Avatar
I hate posts like this... First of all, you have absolutely no idea what's involved. You call one shop, then come on here bitching about the quote.
Is there only one shop in your town that can install springs? Unless you live in bumfuck, then no. If you'd taken the time to call around you'd have quickly figured out what a decent price was.
Shop labor is expensive - they have considerably more overhead than some guy doing the install in your driveway. $650's obviously way too much.
If you don't like that though, wait until you go get quotes for that swap your signature says you want.
Old Dec 4, 2004 | 10:11 AM
vtecaccord 1's Avatar
Default Re: (JeffS)
i agree with jeffs go get some more quotes instead of whining if they are all as high then come bitch.
the best thing to do is take the spring/strut assembly off of the car and take it to a shop with a spring compressor to take the springs dont kill yourself youll save some money on labor and gain knowledge i would say about 1 hour labor to remove and install all of the springs if you take them off yourself.
Old Dec 4, 2004 | 09:14 PM
Hazem's Avatar
Default Re: (VTECHACCORD)
You guys would have a valid point, but I wasn't whining. Look at the post title. "haha" that is a term to convey laughter.
Now GTFO
leave before the admin bans you....leave now figget
truth of cs^^
Old Dec 4, 2004 | 09:23 PM
green-'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTECHACCORD &raquo;</TD></TR><TR><TD CLASS="quote">i agree with jeffs go get some more quotes instead of whining if they are all as high then come bitch.
the best thing to do is take the spring/strut assembly off of the car and take it to a shop with a spring compressor to take the springs dont kill yourself youll save some money on labor and gain knowledge i would say about 1 hour labor to remove and install all of the springs if you take them off yourself.</TD></TR></TABLE>
Punctuation is your friend.
Go to your local auto parts store and rent a spring compressor, no point in being charged for them to do it when you can do it yourself and most likely get your deposit back.
SkoundrelUSA's Avatar
cute little bastard
Thats an absolute bullshit quote. If it takes 3.5 hours per axle he must be retarded. Go somewhere else for a quote or DIY with a manual. I know shops around here don't charge more than 200. The shop i hang out at charges 160 for all corners and it takes about 2 hours max.
Old Dec 4, 2004 | 09:36 PM
DJ_SaNdOz's Avatar
Default Re: Bwahahahahahaha--Shock/Spring installation quote! (SkoundrelUSA)
There is no way in hell that it should take a shop that long; that's nuts!!!
Old Dec 4, 2004 | 10:53 PM
WongFeihung's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkoundrelUSA &raquo;</TD></TR><TR><TD CLASS="quote"> The shop i hang out at charges 160 for all corners and it takes about 2 hours max.</TD></TR></TABLE>
Yep, the highest i've seen here in colorado is 200 and it takes around 2 hours.
Old Dec 4, 2004 | 10:55 PM
EK k kay's Avatar
Default Re: Bwahahahahahaha--Shock/Spring installation quote! (WongFeihung)
I'd do it for 50 bucks or less. They're trying to rip you off. With their tools they can probably do each corner in a matter of minutes.
Old Dec 4, 2004 | 11:51 PM
31flavorscivic's Avatar
Default Re: Bwahahahahahaha--Shock/Spring installation quote! (chowmien)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DJ_SaNdOz &raquo;</TD></TR><TR><TD CLASS="quote">There is no way in hell that it should take a shop that long; that's nuts!!! </TD></TR></TABLE>
The time we did it: 4 people, rear wheels, and we had 2 people working simultaneously on each rear wheel. Time: 40 min.
I do car stuff for free pizza :D
