e-brake light always on
Old Dec 3, 2004 | 07:02 AM
wompwomp61's Avatar
Default e-brake light always on
A couple weeks ago whenever I would take a turn quickly or hit a bump, my ebrake light would go on momentarily, I would tap my brake handle and it would go off. Now its on Always. I think something has to be tightened because its really weak and on steep hills it wont hold my car. Anyone have any experience with this??
Old Dec 3, 2004 | 07:05 AM
LSVTEC 91 Civic's Avatar
Banned
Default Re: e-brake light always on (wompwomp61)
Check your brake fluid, it is probably low. You most likely need new shoes & pads too.
Old Dec 3, 2004 | 07:09 AM
Targa250R's Avatar
be professional
Check the master cylinder reservoir. When the fluid level is low, the float will close a switch to turn on the brake idiot light circuit.
How are your pads wearing? A low fluid level could be caused by low brake pads/shoes . . . or, unfortunately, a leak in the system.
Old Dec 3, 2004 | 08:07 AM
wompwomp61's Avatar
Default Re: e-brake light always on (Targa250R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSVTEC 91 Civic &raquo;</TD></TR><TR><TD CLASS="quote">Check your brake fluid, it is probably low. You most likely need new shoes & pads too.</TD></TR></TABLE>
sigh, i dont know where this is.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa250R &raquo;</TD></TR><TR><TD CLASS="quote">Check the master cylinder reservoir. When the fluid level is low, the float will close a switch to turn on the brake idiot light circuit.
How are your pads wearing? A low fluid level could be caused by low brake pads/shoes . . . or, unfortunately, a leak in the system.</TD></TR></TABLE>
nor do i know where the master cylinder reservoir is.
i'm in need of brake pads. shoes..i dont know what these are either.
i need a helms
Old Dec 3, 2004 | 08:11 AM
Banned
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wompwomp61 &raquo;</TD></TR><TR><TD CLASS="quote">
i need a helms </TD></TR></TABLE>
Brake fluid is on the driver side of the firewall under the hood. Brake pads go on your front discs... while the brake shoes go on your rear drums. Check these 3 things.
89civicdx's Avatar
got these from the ef picture post
See the greenish bottle in the top right of this pic...open the cap and check the fluid level
Old Dec 3, 2004 | 08:13 AM
CRX Toad's Avatar
Master Cylinder (MC) is made out of clearsish plastic and has a gray cap on it, as stated above, it is on the driver side right infront of where your brake pedal is inside.
edit: And someone got a pic of it for you too
Old Dec 3, 2004 | 08:37 AM
wompwomp61's Avatar
Default Re: e-brake light always on (LSVTEC 91 Civic)
Brake fluid is on the driver side of the firewall under the hood. Brake pads go on your front discs... while the brake shoes go on your rear drums. Check these 3 things.</TD></TR></TABLE>
you, you are good. thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89civicdx &raquo;</TD></TR><TR><TD CLASS="quote">
thank you VERY much for that pic
I'll post the level of the fluid when i get home. I know I was in need of pads soon. Where is a good place to pick up pads and shoes?? I know there's so many types of pads out, and i see different opinions. Websites? Is regular oem stuff the best??
Old Dec 3, 2004 | 10:53 AM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wompwomp61 &raquo;</TD></TR><TR><TD CLASS="quote">Is regular oem stuff the best??</TD></TR></TABLE>
Usually. OEM Honda pads and shoes offer the best balance of durability, stopping power, fade resistance, dust, and noise for a daily driver.
In other words, they last a long time, don't squeal, don't make a lot of dust, and stopping power is more than enough for a daily driven street car.
Now, if you wanted a little more bite and fade resistance, you might want to look into upgrading your front pads to something like an Axxis MetalMaster or AEM pad. And if you want the best stopping power available for a street-driven car (and something usable for autocross and light track duty), and don't mind a lot of dust and the occasional squeal, then you may want to check out Axxis Ultimates or Cobalt GT-Sports.
As far as the rear shoes go, OEM Honda is fine.
Old Dec 3, 2004 | 11:06 AM
misfithamster's Avatar
had the same prob man. light would go on and off randomly when i would make turns or hit bumps and crap. then it just finally stayed on for good i couldnt figure out what the hell was goin on! things like that drive me nuts.. had a low fluid level as it turns out.. filled her up, problem solved!
Old Dec 3, 2004 | 11:16 AM
senpai's Avatar
You know, I bet your e-brake light sensor is grounding itself. The light only comes on when the metal part of the e-brake supplies the ground for the light.
Old Dec 3, 2004 | 11:48 AM
b1r469's Avatar
if your brake fluid is low, I would check your brake shoes/pads. Unless your brake fluid is leaking anywhere, your pads are worn.
If you keep driving like this for long, you will feel grinding soon (metal on metal)
Old Dec 3, 2004 | 11:53 AM
EL Vap133's Avatar
Default Re: (b1r469)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b1r469 &raquo;</TD></TR><TR><TD CLASS="quote">if your brake fluid is low, I would check your brake shoes/pads. Unless your brake fluid is leaking anywhere, your pads are worn.
If you keep driving like this for long, you will feel grinding soon (metal on metal)</TD></TR></TABLE>
When was the last time you replaced your brakes?
Old Dec 3, 2004 | 12:24 PM
wompwomp61's Avatar
As far as the rear shoes go, OEM Honda is fine.</TD></TR></TABLE>
Are the axxis pads a good bang for the buck over oem? Given we'd all like stopping power. But its not like my car is so powerful, and its not like i'm going so fast that i need to stop just as quick. I street drive daily, I wont be seeing any autocross or any track for that matter. If the aftermarket pads arent such a drastic inflation over oem, i'd probably get them. Price numbers off the top of your head?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by misfithamster &raquo;</TD></TR><TR><TD CLASS="quote">had the same prob man. light would go on and off randomly when i would make turns or hit bumps and crap. then it just finally stayed on for good i couldnt figure out what the hell was goin on! things like that drive me nuts.. had a low fluid level as it turns out.. filled her up, problem solved! </TD></TR></TABLE>
I checked my fluid and it is low. But I remember filling up back in July. Should it be THIS low since only 5 months ago??
where would i check for a leak?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EL Vap133 &raquo;</TD></TR><TR><TD CLASS="quote">
When was the last time you replaced your brakes? </TD></TR></TABLE>
ah el vap, i got nervous when i saw that you posted. thought you locked it something haha. I've had the car since July and havent so much as touched the brakes. But from the sounds of things, I probably will do this.
Old Dec 3, 2004 | 12:27 PM
EL Vap133's Avatar
ah el vap, i got nervous when i saw that you posted. thought you locked it something haha. I've had the car since July and havent so much as touched the brakes. But from the sounds of things, I probably will do this.</TD></TR></TABLE>
LOL, what, you think I am just out to get people and lock their topics?
Old Dec 3, 2004 | 01:41 PM
wompwomp61's Avatar
Default Re: e-brake light always on (EL Vap133)
LOL, what, you think I am just out to get people and lock their topics? </TD></TR></TABLE>
haha, noooo
Pabs626
Dec 9, 2007 05:02 PM
grandmasterflash
Dec 28, 2005 05:55 AM
Understeer
Dec 1, 2003 09:40 PM
rockwilda
Oct 16, 2002 12:09 PM
Padronis
Jun 29, 2002 07:00 AM
