Need Help: Over Heating problem
Old Dec 2, 2004 | 07:45 PM
C.A.M.'s Avatar
Default Need Help: Over Heating problem
I need help on my buddies CRX. 1990 Si.
The car overheated last summer and shut off. This week I had the cyclinder resurfaced, replaced headgasket and radiator. The car started up no problem. Within 4-5 minutes of running, it temperature gauge climbs slowly towards the "h" (hot) mark. I shut off the car and double check for air in the coolant system. I removed the thermostat and tried running, again within 4-5 it climbs slowly towards the "h".
What can it be?
Corroded, Dirty Temp. Sensor? if. so, where is it located?.. CRX dont have sensor at the water neck like the B-series..
I really need help,
Old Dec 2, 2004 | 08:01 PM
Bgladfelter's Avatar
Default Re: Need Help: Over Heating problem (Souz)
Did you put in a new water pump during this rebuild?
Did you bleed the coolant system? This normally fixes the initial put back together overheating problem.
Old Dec 2, 2004 | 08:20 PM
C.A.M.'s Avatar
Default Re: Need Help: Over Heating problem (Bgladfelter)
coolant system bleed. water pump is fine. anything else?
Old Dec 2, 2004 | 08:24 PM
mr. carpenter's Avatar
thermostat, radiator cap. warped head or block surface. is it leaking?
Old Dec 2, 2004 | 08:38 PM
C.A.M.'s Avatar
Default Re: Need Help: Over Heating problem (mr. carpenter)
radiator cap check,
thermostat taken off,
no leaks,
coolant bleed,
remember guys.. this car has been sitting for 4-5 months. no warped block, head resurfaced, actually holds compression. check piston and spark plugs for signs of wetness, so no leaks
help is very appreciated.
i am assuming its the temp sensor, but dont have a CRX helms manual. its not located on the water neck like the b-series.. Sorry guys. I need your D-series expertise.
Old Dec 4, 2004 | 10:36 PM
C.A.M.'s Avatar
please to the top.. I need help..
I've done lots of searching.. nothing yet.
any one had any similar problem before.
2000eK_cIvIc
13
Apr 19, 2011 05:04 PM
usdm_3g
Classic Hondas
Feb 25, 2009 08:43 AM
greenlikematt
10
Jul 22, 2008 06:30 PM
mrx
Jul 4, 2006 07:44 AM
jadugartir
Aug 4, 2005 12:15 PM
