What is this sound?
Old Dec 2, 2004 | 06:43 PM
ExcessiveCRX's Avatar
Default What is this sound?
Okay when I shut off my motor it makes a sort of compression sound kinda like suction, is this a bad thing or normal? The motor seems to run excellent and is having no problems.
My old 320000km si motor never made that sound
Old Dec 2, 2004 | 06:53 PM
CRseXy's Avatar
Default Re: What is this sound? (ExcessiveCRX)
I think it has to do with ur intake. my friends 02 civic does it, and you can hear it thru his intake.
Old Dec 2, 2004 | 07:13 PM
mr. carpenter's Avatar
Default Re: What is this sound? (pogiTSI)
might be sucking air through the idle adjust screw. i just had to replace mine because the rubber coating on it had dry rotted.
Old Dec 2, 2004 | 07:24 PM
JohnnyLux's Avatar
my girlfriends civic does that, its just from the intake. it kinda sounds like its lettin off pressure.
Old Dec 2, 2004 | 07:37 PM
31flavorscivic's Avatar
Default Re: What is this sound? (civic90)
intake. You can hear it on any car if you run open throttle body.
Old Dec 2, 2004 | 07:59 PM
B16 ED9's Avatar
Default Re: What is this sound? (31flavorscivic)
Of course it the intake, mine does the same **** ( AEM short ram) dont worry its normal
Old Dec 3, 2004 | 12:34 PM
Default Re: What is this sound? (B16 ED9)
must be because my bumper has a big damaged/modified "air route" right up to the intake box thanks for helping me out ht
Old Dec 3, 2004 | 12:36 PM
Default Re: What is this sound? (mr. carpenter)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mr. carpenter &raquo;</TD></TR><TR><TD CLASS="quote">might be sucking air through the idle adjust screw. i just had to replace mine because the rubber coating on it had dry rotted.</TD></TR></TABLE>
Also I will check this out, my throttle body is the original old one maybe I will just get a new tb
Old Dec 3, 2004 | 01:52 PM
kim_2_da_chee's Avatar
I believe every honda motor makes that sound when shutting off the car. It's like a little "psssshhhhh" noise right? It's normal... no worries.
sk8member
Jan 16, 2013 02:57 PM
JDM EJ2
14
Feb 26, 2009 03:52 PM
geewa007
Sep 9, 2008 11:54 PM
power11
Jun 26, 2007 02:34 PM
dave3231
May 18, 2007 04:41 PM
