Car Wont Start
Old Dec 2, 2004 | 06:29 PM
Fatty_1775's Avatar
Default Car Wont Start
Okay, so my car has almost half a tank, and i try to start it, it turns over but dies right away, new battery, and it started this morning and it wasnt plugged in, so i dont think the cold has anything to do with it. The only time this happened was when my car was low on fuel and the problem was corrected when i added gas. Any ideas?
Oh yeah, 91 automatic cx
Old Dec 2, 2004 | 07:15 PM
mr. carpenter's Avatar
Default Re: Car Wont Start (Autobot_Killer)
fuel filter or the fuel pump is probably going out.
Old Dec 2, 2004 | 07:23 PM
Fatty_1775's Avatar
Default Re: Car Wont Start (mr. carpenter)
how can i find out if its the fuel filter or the fuel pump?
Old Dec 2, 2004 | 07:30 PM
turn the key to the on position. you should hear a whirr noise behind the drivers seat under the back seat. that's the fuel pump priming pressure to the fuel system. if you don't hear it than it's gone bad. the fuel filter i would just go ahead and replace. they are cheap. it's in the engine bay on the firewall.
Old Dec 3, 2004 | 05:29 AM
Fatty_1775's Avatar
i have an extra fuel pump from my 92 civic, can i use that on my 91?
Old Dec 3, 2004 | 05:37 PM
Fatty_1775's Avatar
its warmer, so we towed my car to my friends heated garage, and now it starts!! frozen fuel line? how can this be prevented?
Old Dec 3, 2004 | 05:46 PM
sit220's Avatar
wait did u check ur main relay
that can go bad too and could be the reason
Old Dec 3, 2004 | 07:59 PM
Fatty_1775's Avatar
Default Re: Car Wont Start (sit220)
no, i havent checked the main relay, i have heard about these problems, how do i know if there is something wrong with it?
dre33333
Dec 2, 2020 07:24 AM
touge killa
Sep 7, 2018 02:28 AM
hermtm2
23
Apr 8, 2009 06:17 PM
blinger
Sep 1, 2007 10:35 PM
diewX3
Jan 11, 2005 11:50 AM
