H22a4 ignition timing questions..
Hey guys..
Was wondering if you guys know how much timing the h22a4 runs at WOT, assuming for stock motor.. Is there a general trend as the RPMs increase while in WOT (more timing? less timing?)
I'm trying to figure out Uberdata for a boosted application, and it seems best if I have the correct stock values in before I start retarding the timing based on boost..
Any help would be great.. thanks!
Yeh I was considering using the p13 map too.. but it's *SLIGHTLY* different..
just decided to try to see if anyone had one specifically for h22a4 or knows the values.
^^are you sure abotu that? all the basemaps I seen so far show a timing advanced with increasing RPM, but retarded with increasing throttle...
