CRX Dash swap questions...
Old Dec 2, 2004 | 07:58 AM
DCI VW's Avatar
Default CRX Dash swap questions...
after going through the search, i've found out it bolts up. awesome.
now, my question that i couldn't find is this:
how much of my current dash pieces fit into the CRX dash? i have basically, the dash "shell", or dash pad if you will. that's it.
i BELIEVE it's a 90+ dash, my car is an 89 DX h.b.....what am i going to have to locate to complete the dash?
another question that arose, when looking at parts on ebay, was the center console, i know it's different, but what goes in that gapping hole in the middle of it? it's just below the radio hole, or what i'm lead to believe is the radio hole cutout...i could be wrong and it could be for the climate controls...
thanks for the help, sorry if the questions seem stupid, i'm new.
Old Dec 2, 2004 | 08:14 AM
PHOBIA's Avatar
its fro the climate controll.you need the gauge cluster and the whole center consol + air vents and clock? go to a junk yard it will prolly be $50-100 for the rest of it.
Old Dec 2, 2004 | 08:15 AM
CRX Toad's Avatar
Default Re: CRX Dash swap questions... (DCI VW)
Not a whole lot of parts will swap from a HB dash to CRX dash. I would encourage you to keep you current dash and aquire a center console from a newer Integra and swap that in that way you get an armrest and cup holders, something us CRX guys can only dream about
Old Dec 2, 2004 | 08:34 AM
vtecn8ive's Avatar
Default Re: CRX Dash swap questions... (CRX Toad)
Wow that was confusing
Old Dec 2, 2004 | 09:03 AM
DCI VW's Avatar
Default Re: CRX Dash swap questions... (vtecn8ive)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecn8ive &raquo;</TD></TR><TR><TD CLASS="quote">Wow that was confusing</TD></TR></TABLE>
my post was confusing? how so?
thanks for the info...i'm gonna do the swap, just cause. i bought the dash pad for $70 when i first picked up the car, i'm gonna be mad at myself if i just throw it away...not to mention, it's black and my dash is blue... blue dash = teh gay....
will the gauge cluster itself, need to be replaced, or just the bezel around it?
is a CRX cluster going to plug into my harness and work properly?
Old Dec 2, 2004 | 09:09 AM
vtecn8ive's Avatar
Maybe me being stupid. but you are trying to put a CRX dash in a Civic? Your civic is 89? And the CRX dash is 90-91?
I'm I right?
I have heard its a lot of work to get them to fit. Whats wrong with your dash?
Old Dec 2, 2004 | 09:12 AM
DCI VW's Avatar
yes, you are correct.
What's wrong with my dash? nothing, it all works...it's just...
it's blue.
and boring.
the crx dash i have is black and in good shape. and from the looks of it, it's a little nicer looking than the stock dash.
that's all.
edit: i'm about to hit my 5 posts per day limit here...awesome.
Old Dec 2, 2004 | 09:21 AM
vtecn8ive's Avatar
repost using the edit
Old Dec 2, 2004 | 06:27 PM
PHOBIA's Avatar
yeah i got a teg centerconsol in my hb.i love it.that cost me about fifty bucks
Old Dec 2, 2004 | 06:32 PM
HatchBox's Avatar
Skoobie no more...
Default Re: (PHOBIA)
general rule of thumb 88-89 are the same and 90-91 are the same.
your going to need the whole dash from a 88-89 crx, including cluster.
I beleive in oreder to run the crx(90-91) cluster you have to repin some wires for the cluster to work right
Old Dec 2, 2004 | 07:05 PM
fourthgenhatchB17's Avatar
Default Re: (HatchBox)
PM eggman. He has a CRX dash in his 88-89 hatchback.
Old Dec 3, 2004 | 11:43 AM
DCI VW's Avatar
i can't use the PM feature yet...i'm still a noob.
to make sure it's from a 90-91 crx, how can i tell? are there any differences that i can tell when the dash is bare and has absolutely nothing on it.
Old Dec 3, 2004 | 11:47 AM
CRX Toad's Avatar
Default Re: (DCI VW)
The dashes are the same 88-91 the difference is in the gauge cluster, The 88-89 gauges and cover are square, where the 90-91 guages and cluster are bigger and rounded
Old Dec 3, 2004 | 02:03 PM
Shaguar47's Avatar
Default Re: (CRX Toad)
Alright, let me clear this up. I actually just did this swap around halloween so I know what's needed at what's not. I did a 90 crx dash into my 90 hatchback. It worked out great.
1. You can use your two side vents, they will fit. Mine were broken to begin with so they'll work. But not the center vent. Keep the one on the crx.
2. The clocks are interchangable.
3. The civic glovebox can be used. It'll fit right up.
4. If the civic has tilt, keep the fusepanel. But if not, you'll have to get the crx one cause you'll have to lower your steering column cause the gauges sit lower than the civic one.
5. Your climate controls will fit and so will your radio, even the cigerrate lighter plugs will plug up to your civic.
6. The two door defroster vents are the same on the civic so they can be used.
7. Be sure to get the gauge cluster and do get the metal tabs that hold the cluster on cause the civic ones are taller and bolting it up won't make the cluster fit under the cluster cover.
8. Get all the bolts
9. Everything bolts up fine, it's a flush fit, and it looks awesome.
But Warning: 88-89 crx dashs must be used with the 88-89 civics. The gauge cover is different so is the width of the dash. Somehow the dashs in 88-89 are shorter than 90-91 cause there is a gap at the window and on the passengers door side. Even the clusters are different so just a word of advice, use the years corresponding to your model. In the end, it'll turn out great. Mine did!
Old Dec 3, 2004 | 08:18 PM
DCI VW's Avatar
Default Re: (Shaguar47)
ok, that helped a lot more than anything else i've figured out.
how can i for sure tell if it's a 90 dash though? if there's a vin plate still on it, is there a digit i can look at that would tell me (i dont remember if it's still on there or not)...there should be one, but i have no idea what digit it would be...
if there's not a vin, is there another way to tell?
i mean, if i post a picture up, would that help?
Old Dec 4, 2004 | 09:23 AM
PHOBIA's Avatar
if you pull it out of the car look at the frame and read the year.but again,the 88-89 gauge cluster were really boxy and square,the 90-91 are bigger,if you see them side by side you can really tell the diff,its easy to spot.
Old Dec 4, 2004 | 05:58 PM
DCI VW's Avatar
i didn't pull the dash out of the crx...it was delivered to me from a guy that picked it up in portland....the kid moved, i dont see him anymore.
i also didn't get the dash with a cluster, or cluster bezel...i know what the difference is between the two clusters...but i dont have a bezel from the 'rex for this dash to be able to tell...it's bare.
i'll just have to try it out...and i'm also assuming that i can move tabs and what not to fit my cluster onto it...i can probably move the tabs that the screws would go into that hold the bezel on, as well...
Old Dec 4, 2004 | 06:30 PM
eumoria's Avatar
i have an 88 STD with a 91 CRX Si dash
i'm using an 89 Si cluster with an 88 Si gauge cover
i made it work, you can too. All the vents work, clock works, hooray.
Old Dec 4, 2004 | 10:21 PM
DCI VW's Avatar
Default Re: (eumoria)
beautiful. that's what i wanted to hear.
thanks.
Bertamus
18
Oct 20, 2010 12:13 PM
Peters1983
Aug 29, 2004 06:56 PM
xsellxoutx
11
Dec 29, 2003 09:46 AM
shoebox
Nov 6, 2002 08:30 AM
