tranny to block bolt hole stripped
ok the other day i noticed that one of the large 17mm bolts that hold the tranny to the block was loose. i tried to tighten it up and it went in but wont get tight. it gets to sitting flush with the tranny and then just spins. i at first thought that the bolt had broken off in the block but i removed the bolt and its intact. it seems to partially grab the threads with no real torque on it but it wont hold the torque at all. i can see parts of the blocks threads on the bolts threads. im sure its stripped out. has anyone had this happen? i know its not a HUGE deal since it has plenty of other support, but id rather not leave it like that. what should i do to fix this? drill out the block and retap for a larger bolt? is there anything i could do to the block to restore the threads of the same size? any help is greatly appreciated.
From: hittin corners so hard you can taste my rims..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Magick211 »</TD></TR><TR><TD CLASS="quote">If you want to keep the threads the same size i bileve you could helicoil it.</TD></TR></TABLE>
negitive.. there are better tools than heli-coil.
take a look at this.
https://honda-tech.com/zerothread?id=1070933
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Built B16A »</TD></TR><TR><TD CLASS="quote">
https://honda-tech.com/zerothread?id=1070933 </TD></TR></TABLE>
If he does it that way he wont be able to use the factory 17mm bolt will he?
try to you some catalyst penetrating lub and then use a vise grip.. try this back and forth.. also i would also try to tap on it lightly... then if all else fails just buy that bolt grip set... im pretty sure there are kit that includes 17mm bolt grip...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92integra_gs »</TD></TR><TR><TD CLASS="quote">try to you some catalyst penetrating lub and then use a vise grip.. try this back and forth.. also i would also try to tap on it lightly... then if all else fails just buy that bolt grip set... im pretty sure there are kit that includes 17mm bolt grip... </TD></TR></TABLE>
huh? the bolt isnt stuck in there man, the bolt comes out fine, the threads are just fuckes and the bolt wont tighten.
everyone else thanks for the replies. that sleeve thing looks like a good solution but i wouldnt know where to get it and im sure its expensive. im trying to go a cheaper way.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Magick211 »</TD></TR><TR><TD CLASS="quote">If he does it that way he wont be able to use the factory 17mm bolt will he?</TD></TR></TABLE>
yes he will... its a sleave that supports a 17MM 1.25 bolt. just like factory.
i had the same problem,i noticed i had a huge gab between my tranny and block,i tried to tighten it down and it wasnt working so i pulled the bolt out and my treads were on the bolt,i ended up using a slightly short bolt and i put the threads that were on the other bolt onto the new to make a little snugger fit and put a lot of jb weld on it,its been 3 or 4 monthsand i havent had a problem. at the time i was grinding gears real bad,i didnt have time to tap it so its was a quick fix that has not let me down yet.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSRCRXsi »</TD></TR><TR><TD CLASS="quote">how much is that kit?</TD></TR></TABLE>
if you were reffering to mine... i recall somewhere in teh neighborhood of about 50 bucks... and i think about 10 or 12 sleaves.
its saved my *** a few times.. im glad i have them.
OrangeBoost
May 4, 2006 02:49 PM
headhunter
Feb 22, 2005 02:26 PM
. If it was my car, I would retap it
