Transmission filler bolt woes. Need help URGENT :o
The gun won't fit in that tight space to get at the tranny fluid filler bolt. We don't have a breaker bar. We tried using a half inch drive with an extension, and that didn't work either. However I was told today that you could actually fill tranny fluid through the half inch drive bolt to the RIGHT of the drain bolt. Any confirmation on this?
*urgent*
Need to have the car running by tomorrow afternoon.
*urgent*
Pull out the VSS. One 10mm bolt holding it to the trans case and then pull it right up. Remember to take off the vent tube cap before you fill it and put a little over 2 quarts in.
spec is 2.3qt
spec is 2.3qt
doom26464
Jun 18, 2008 07:10 PM
asubennett
Aug 21, 2003 05:14 PM
RCautoworks
Feb 16, 2003 11:16 PM
