It feels like I lose a cylinder sometimes
During the summer every once in a while when the car was cold it would feel like I lost a cylinder for a second. I'd be in 2nd getting out of the neighorhood accelerating and suddendly it would stop accelerating, then go back again. Now that it's gotten cold it's doing it worse. The problem is that I don't know what the engine's not getting, fuel, air, or spark. I'm planning on taking the dist. out and checking it, cleaning the TB, and putting a new fuel filter in to see if it does anything. Is there anything else I should look aat while I'm in there?
Does your car sound like a wrx..??
I know when I-4 motors run on 3 cylinders they sometimes sound like that
Maybe you have a misfire..
check what "2point2" said to check
IAm would like to know as well
cuz Iam having a similar problem myself, but my ECU dosent flash any codes, and no my PR3 ecu is not faulty.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ewaugh »</TD></TR><TR><TD CLASS="quote">actually the other day I was getting #1 (91 Si ECU), but I cuoldn't figure out what it was.</TD></TR></TABLE>
1 is for the O2 sensor.
https://honda-tech.com/zerothread?id=468260
A cut in the number 2 plug wire outer was causing all my problems. The car runs much smother with a new set of wires. I'll check that O[sub]2[/sub] sensor out too.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ewaugh »</TD></TR><TR><TD CLASS="quote">A cut in the number 2 plug wire outer was causing all my problems. The car runs much smother with a new set of wires. I'll check that O[sub]2[/sub] sensor out too.</TD></TR></TABLE>
Good stuff.. i hope you replaced the rest of the stuff along with that!
Yeah with a cylinder not firing it will throw a code for the O2 sensor.Reset the ECU and see if it comes back on.
The distrubitor doen't have many miles on it, so I didn't need to replace that. It is about time for plugs though...and an oil filter
Thanks Guys
Thanks Guys
purple98ek
Mar 19, 2006 07:04 PM
