It feels like I lose a cylinder sometimes
Old 12-01-2004, 06:43 PM
ewaugh's Avatar
Default It feels like I lose a cylinder sometimes
During the summer every once in a while when the car was cold it would feel like I lost a cylinder for a second. I'd be in 2nd getting out of the neighorhood accelerating and suddendly it would stop accelerating, then go back again. Now that it's gotten cold it's doing it worse. The problem is that I don't know what the engine's not getting, fuel, air, or spark. I'm planning on taking the dist. out and checking it, cleaning the TB, and putting a new fuel filter in to see if it does anything. Is there anything else I should look aat while I'm in there?
Old 12-01-2004, 07:46 PM
2point2's Avatar
Default Re: It feels like I lose a cylinder sometimes (ewaugh)
cap, rotor, wires, plugs, grounds.
are you getting an o2 code by any chance?
Old 12-01-2004, 07:51 PM
mrspeaker's Avatar
Default Re: It feels like I lose a cylinder sometimes (2point2)
Does your car sound like a wrx..??
I know when I-4 motors run on 3 cylinders they sometimes sound like that
Maybe you have a misfire..
check what "2point2" said to check
Old 12-01-2004, 09:00 PM
B16 ED9's Avatar
Default Re: It feels like I lose a cylinder sometimes (Mrspeaker)
IAm would like to know as well cuz Iam having a similar problem myself, but my ECU dosent flash any codes, and no my PR3 ecu is not faulty.
Old 12-02-2004, 07:10 AM
ewaugh's Avatar
Default Re: It feels like I lose a cylinder sometimes (B16 ED9)
actually the other day I was getting #1 (91 Si ECU), but I cuoldn't figure out what it was.
Old 12-02-2004, 09:26 AM
be professional
Targa250R's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ewaugh &raquo;</TD></TR><TR><TD CLASS="quote">actually the other day I was getting #1 (91 Si ECU), but I cuoldn't figure out what it was.</TD></TR></TABLE>
1 is for the O2 sensor.
https://honda-tech.com/zerothread?id=468260
Old 12-02-2004, 09:28 AM
BigBooster's Avatar
Default Re: It feels like I lose a cylinder sometimes (Targa250R)
sounds like fuel cut mr2's and dsm's get (im sure other cars get them too).
Old 12-02-2004, 10:13 AM
ewaugh's Avatar
Default Re: It feels like I lose a cylinder sometimes (BigBooster)
A cut in the number 2 plug wire outer was causing all my problems. The car runs much smother with a new set of wires. I'll check that O[sub]2[/sub] sensor out too.
Old 12-02-2004, 02:01 PM
2point2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ewaugh &raquo;</TD></TR><TR><TD CLASS="quote">A cut in the number 2 plug wire outer was causing all my problems. The car runs much smother with a new set of wires. I'll check that O[sub]2[/sub] sensor out too.</TD></TR></TABLE>
Good stuff.. i hope you replaced the rest of the stuff along with that!
Old 12-02-2004, 02:31 PM
Lil Red CRXsi's Avatar
Yeah with a cylinder not firing it will throw a code for the O2 sensor.Reset the ECU and see if it comes back on.
Old 12-02-2004, 02:42 PM
ewaugh's Avatar
Default Re: It feels like I lose a cylinder sometimes (Lil Red CRXsi)
The distrubitor doen't have many miles on it, so I didn't need to replace that. It is about time for plugs though...and an oil filter
Thanks Guys
Old 12-02-2004, 08:46 PM
NaticusRex's Avatar
Is your tach doing anything funny? One day my zc started missing randomly and it turned out that the crank sensor was on its way kaput.
gerbs94integra
03-10-2010 11:06 AM
purple98ek
03-19-2006 07:04 PM
wong
01-19-2005 04:48 PM
acqua20
07-16-2002 07:52 PM
Quick Reply: It feels like I lose a cylinder sometimes
