how to test for leak in tires?
Old Dec 1, 2004 | 05:07 PM
sloz64now's Avatar
Default how to test for leak in tires?
well the other day mt psi was at like 8!!! i filled it up to almost the max and it looks like its getting lower, is there a way that i can put it in water or something to see where its coming from?
Old Dec 1, 2004 | 05:10 PM
AWDxBOOST's Avatar
Default Re: how to test for leak in tires? (sloz64now)
water will work just fine
Old Dec 1, 2004 | 05:18 PM
civic99b16a's Avatar
Default Re: how to test for leak in tires? (itr_eg)
ive use to deal with this **** all day i use to work at town fair tire i would inflate it to 35psi or so and spray soapy water onto it make sure to check the valve stem and the tire bead to make sure its not leaking from there eighter also dont stick plug it they suck and most likely it will end up leaking again. have it patched from the inside as long as its not to close to the sidewall you'll be all set
Old Dec 1, 2004 | 05:19 PM
DAguyLS's Avatar
just get soapy water and fill the tire up with air and then spray the soapy water on the tire and wait to see bubbles, and there's your leak
Old Dec 1, 2004 | 05:21 PM
butters's Avatar
Default Re: (slamdcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slamdcivic &raquo;</TD></TR><TR><TD CLASS="quote">just get soapy water and fill the tire up with air and then spray the soapy water on the tire and wait to see bubbles, and there's your leak</TD></TR></TABLE>
yes the ol' soap technique works good
Old Dec 1, 2004 | 05:29 PM
sloz64now's Avatar
Default Re: (butters)
k thanks guys i think ill do it tomorrow.
Old Dec 1, 2004 | 05:44 PM
Team 4R's Avatar
Default Re: (sloz64now)
take the wheel off and dunk it in the pool..... that way you'll know where ALL the leaks are, should there be more than one.... i always get a weird look when i suggest that idea. i dunno why, it works really well....
Old Dec 1, 2004 | 05:46 PM
pdiggitydogg's Avatar
most tire places will fix it for free anyway...I just take mine in
hondatech.101
Honda Fit
Sep 6, 2019 10:34 AM
'90crxSI
12
Sep 4, 2006 03:48 PM
scyked
Apr 12, 2006 03:45 PM
90JPRCRX
Jan 20, 2005 01:52 PM
integraL
Jul 18, 2003 02:29 AM
