700 for piston install?????
Old Dec 31, 2001 | 10:53 AM
speedymon's Avatar
Default 700 for piston install?????
WTF is that an average price? Wanna know if i'm getting *** raped!
Old Dec 31, 2001 | 11:27 AM
Crazydave's Avatar
Default Re: 700 for piston install????? (speedymon)
I got engine balanced and blueprinted for 767 including rings, bearings, and bottom-end assembly, also included magnaflux
[Modified by Crazydave, 12:28 PM 12/31/2001]
Old Dec 31, 2001 | 11:29 AM
b18bvudoo's Avatar
New User
Default Re: 700 for piston install????? (Crazydave)
where'd you get it done?
Old Dec 31, 2001 | 12:03 PM
speedymon's Avatar
Default Re: 700 for piston install????? (vudoo666)
not done yet just got an estimate. Is that a good price or what? i wanna know.
Old Jan 1, 2002 | 09:31 AM
speedymon's Avatar
ttt
Old Jan 1, 2002 | 10:49 AM
OneThirtyEight's Avatar
Tell him you can do 600 Its all about the labor costs man, time is money.
Old Jan 2, 2002 | 11:03 PM
l's Avatar
l
700 just to put the pistons in??? what all are they doing for this 700?
i had to replace rod bearings in the ZC im using so i pulled the pistons out and putting them BACK in was cake...
now machining would get costly
Old Jan 2, 2002 | 11:07 PM
Default Re: 700 for piston install????? (IM ALL SHO)
I would assume piston install means take the old ones out, put new pistons and rings on, clean the inside of the walls, rebalance, and reassemble.
Old Jan 3, 2002 | 06:20 AM
Crazydave's Avatar
Default Re: 700 for piston install????? (97blackteg)
I tore up to rod bearings and a two mains so I had the cylinders, crank, rods, journals machined. Everything was machined, new rings, bearings and balancing.
Old Jan 3, 2002 | 07:15 AM
WAFFLES's Avatar
That's a little much. I went to a local machine shop that did all my work except for blueprinting; here are the costs.
Pressed pistons on rods and balanced both:$60
Bored block was about $50(i'm not 100% on that)
crank was balanced and micropolished for $80
Assembly and blueprinting was done by H-T member MIDNIGHT. IM him for any work that you might want done. He has some of the best prices around and excellent work.
The machine shop is local and is KNOWN for its work with numerous funny cars and other drag cars. They do top notch work at a rerasonable price.
Old Jan 3, 2002 | 12:27 PM
speedymon's Avatar
Default Re: 700 for piston install????? (WAFFLES)
Yeah well i'm in Va....yeah that is kinda high..but how else am i gonna get compression above 11. I have a GSR.
Old Jan 3, 2002 | 12:32 PM
WAFFLES's Avatar
just keep checking your local machine shops!
Old Jan 3, 2002 | 01:47 PM
ahcjar103's Avatar
well, when you ad disassembly, cleaning, new bearings, new seals, hone or bore, pressing of wristpins, rings, and then assembly, i could see how it could come to 700.
Old Jan 3, 2002 | 04:09 PM
AlphaKennyWun's Avatar
Default Re: 700 for piston install????? (ahcjar103)
I was quoted to install pistons and rods and you bring them the block was $200 at sfp 5 months ago. Nothing else just putting in the pistons and rods...that is all.
Old Jan 3, 2002 | 06:44 PM
JunCivic Hatch's Avatar
New User
I'm getting mine done at a loal machine shop for $452
$25 to press the piston & rods
$32 to hone the block
$20 to mic & polish the crank
$75 to wash the everything
$150 to balance
$150 to assemble everything
Only thing was I had already pulled the old piston and rods out of the block so I'm actually saving the guy some time/labor. Hope that helps.
BTW I'm replacing the stock pistons & rods.
[Modified by JunCivic Hatch, 10:46 PM 1/3/2002]
Old Jan 3, 2002 | 07:13 PM
Big Teggie's Avatar
Default Re: 700 for piston install????? (JunCivic Hatch)
JunCivic Hatch- Where in NJ are you getting this work done. I plan on get pistons by the end of the month and i dont know of any reliable machine shops around me. I would like to know the place so i can get my **** done. Thanks alot.
Old Jan 3, 2002 | 07:24 PM
New User
Default Re: 700 for piston install????? (Big Teggie)
Big Teggie: you got mail
btw how do you like your Skunk2 Manifold? Do you have cams as well?
[Modified by JunCivic Hatch, 11:37 PM 1/3/2002]
Old Jan 3, 2002 | 07:36 PM
Big Teggie's Avatar
I just checked my mail, nuttin their.
Old Jan 3, 2002 | 07:37 PM
New User
Sorry, check again. It's coming from hotmail. I had posted before the email
You should have it now.
Old Jan 5, 2002 | 10:19 AM
KayOs's Avatar
Looking to do the same, but looking to try new avenues. That sounds like a good price. I did the same thing you did JunCivic Hatch (took out old pistons from block). If you can, hit me up with the location of this machine shop. Thanks.
ITR.#1446
Jul 22, 2008 09:34 PM
aznboi_2
May 9, 2006 03:54 PM
AlienKrOZ
Apr 27, 2006 08:54 AM
Boltz
Sep 17, 2004 07:30 PM
P1mpSlap
Jul 9, 2003 11:46 AM
