are ground wires worth my time
Old Dec 1, 2004 | 02:35 PM
Ping1831's Avatar
Default are ground wires worth my time
I just bought a 97 accord ex. I am in the process of doing work under the hood and my freind said i might consider some red ground wires to go with the rest of red produicts i have. I will eventually buy a stereo system for my car this is why i thought i might want to get ground wires. I can get them fairly cheap and they will dress up under my hood a little more. Are the ground wires worth my time/.
Old Dec 1, 2004 | 03:49 PM
drkblue_civic's Avatar
Default Re: are ground wires worth my time (Ping1831)
performance wise...probably not (maybe) as far as stereo goes though, yeah they are worth it...less voltage drops or in some instances higher voltage
Old Dec 1, 2004 | 03:57 PM
EBP_SI's Avatar
Default Re: are ground wires worth my time (drkblue_civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drkblue_civic &raquo;</TD></TR><TR><TD CLASS="quote">performance wise...probably not (maybe) as far as stereo goes though, yeah they are worth it...less voltage drops or in some instances higher voltage </TD></TR></TABLE>
for a stereo though, the only ground you really have to worry about is the battery to chassis.
Old Dec 1, 2004 | 04:07 PM
kontai69's Avatar
Default Re: are ground wires worth my time (EBP_SI)
The chassis to engine block ground wire is also important.
Here is a good article on upgrading ground wires...
http://forum.sounddomain.com/u...07801
Old Dec 1, 2004 | 05:11 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EBP_SI &raquo;</TD></TR><TR><TD CLASS="quote">for a stereo though, the only ground you really have to worry about is the battery to chassis. </TD></TR></TABLE>
not exactly running a 4 gauge wire (or any large gauge) from alternator (+) to the battery (+) helps stereo wise as well
Old Dec 1, 2004 | 05:12 PM
Default Re: are ground wires worth my time (kontai69)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kontai69 &raquo;</TD></TR><TR><TD CLASS="quote">The chassis to engine block ground wire is also important.
http://forum.sounddomain.com/u...07801</TD></TR></TABLE>
oops wasnt paying attention...yeah that link shows the way
Old Dec 1, 2004 | 05:43 PM
EBP_SI's Avatar
not exactly running a 4 gauge wire (or any large gauge) from alternator (+) to the battery (+) helps stereo wise as well </TD></TR></TABLE>
you're right...i forgot about that one.
rs_sexy
Oct 11, 2006 01:51 PM
quagmire
Oct 4, 2006 07:38 PM
Preludster
Sep 9, 2003 10:40 AM
Whitegsr2000
Jun 1, 2003 07:28 PM
THE94GSR
May 28, 2003 08:53 AM
