running s2s1 in my car
Old Dec 1, 2004 | 12:20 PM
typesguy's Avatar
Default running s2s1 in my car
i got a 99 gsr, im getting ready to put some s2s1 in my car my setup is going to be
mods
-cai
-dc 4-1 header
-high flow cat
-2.5in exhaust
-exedy clutch
-exedy flywheel
-B&M fpr
-s2s1
when i put these in my car do I need to do anything special to get these to run right in my car?
do i need to turn the fuel pressure up a little bit to provide enough fuel for the cams?
can i still run 18 degrees of timing with the cams?
Old Dec 1, 2004 | 01:35 PM
ALLMOTOR18's Avatar
Default Re: running s2s1 in my car (jaydmdc2)
I would suggest getting a VAFC or a VTEC controller. With those cams in a GSR head, stock VTEC kicks in a bit too low. You can feel the dip in power.
18 degrees timing is fine. You may want to bring up the fuel pressure 1-2 psi.
Goodluck..
Old Dec 1, 2004 | 05:27 PM
typesguy's Avatar
ok thanks man i got a vafc 2 on the way. what do think i should raise the vtec to?
Old Dec 1, 2004 | 05:59 PM
mtber's Avatar
I am assuming you will be running stock injectors ?
Set your b&m at 52 psi at Wide open throttle. (read the manual on checking wot fuel pressure).
What ecu are you running ?
You may want to consider a chipped ecu due to the fact that your stock p72 ecu engages vtec way too early for those cams.
You are going to want vtec activation at around 5300-5600 rpms with those cams.
Old Dec 1, 2004 | 06:15 PM
Ketone's Avatar
Default Re: (mtber)
I say you get a kenji ecu. I ran that in my car for a while before I got hondata, and really liked it ( I was using skunk stage 1 also). Just tell him you would like a program that is not so rich and it will be you will not be disappointed
Old Dec 1, 2004 | 06:52 PM
typesguy's Avatar
do i take the vac line off and set it at 52? is that how you set it at wot because i don't have the manual no more.also by raising my up to 5300rpm im goona loose alot of the low end power i had or im i goin to gain any low end by raising the vtec and having these cams
Old Dec 1, 2004 | 08:00 PM
typesguy's Avatar
Default Re: (jaydmdc2)
bump
Old Dec 1, 2004 | 09:12 PM
ALLMOTOR18's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jaydmdc2 &raquo;</TD></TR><TR><TD CLASS="quote">do i take the vac line off and set it at 52? is that how you set it at wot because i don't have the manual no more.also by raising my up to 5300rpm im goona loose alot of the low end power i had or im i goin to gain any low end by raising the vtec and having these cams</TD></TR></TABLE>
Yes, you take the vac. hose off and set fuel pressure. I recommend setting VTEC around 5100-5200. Losing low end will not be a problem. My motor seemed to feel stronger on the low end when I dropped in the Stage 1's. Passing in 5th gear was no longer a problem after the cam install.
Old Dec 1, 2004 | 10:13 PM
typesguy's Avatar
thanks man youv'e been a big help
Old Dec 2, 2004 | 06:40 AM
typesguy's Avatar
bump
jdragon1974
May 7, 2014 09:40 AM
underpressure02
Oct 21, 2005 05:44 AM
typesguy
Nov 16, 2004 01:14 PM
todaspecsi
Mar 10, 2004 01:12 PM
93preludeh22
Sep 23, 2003 03:38 PM
