fuel pump not working ?
ok i have this setup. 2000 cx hatchback with a 99gsr motor. I am running the 99-00 civic si wiring harness and boombslang jumperharness.with a p28 thats chipped with hondata (s100B).... I turned the key to the position before i start the car and I dont hear the fuel pump cut on like it used to. I am still runnning the sohc fuel pump ...also should I put a gsr pump in there ? I checked the fuel pump fuse under the dash any help would be appreciated ...thanks danny also do you guys think it could be a pinout on the ecu ??
civic2liters
Jun 1, 2008 08:11 PM
