tranny question.
Old Dec 1, 2004 | 11:14 AM
92-LS-Civic's Avatar
Default tranny question.
on this link there is a picture https://honda-tech.com/zerothread?id=960527 it points where to fill up the tranny. also in the picture there are two more bolts on the front of the tranny, are you suppose to put any fluid in there? i am doing a motor swap, and it came with no fluid in the tranny. i put tranny fluid in the check plug that it points to in the picture, but when i go to disingauge my clutch it would die if i let it all the way out. thanks
Old Dec 1, 2004 | 12:08 PM
snatch's Avatar
Default Re: tranny question. (zdowell17)
In that picture, the top plug is the fill plug and the lower one is the drain plug. You can either fill it from the fill plug (upper plug), or the VSS hole which is on top of the tranny. HTH
Old Dec 1, 2004 | 12:13 PM
sammysnakes's Avatar
Default Re: tranny question. (******)
VSS hole is the easiest way to put in tranny fluid.
Old Dec 1, 2004 | 02:26 PM
PrettyLude's Avatar
Default Re: tranny question. (chainsaw)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chainsaw &raquo;</TD></TR><TR><TD CLASS="quote">VSS hole is the easiest way to put in tranny fluid. </TD></TR></TABLE>
that is so true, i would hate to pour in oil through the other way to fill it up
Old Dec 1, 2004 | 07:48 PM
i dont know but i think you didnt get what i was tring to say! the two that are marked, i already filled. in that same picture on the very end of the tranny, it would be right next to the passenger side firewall, are another set of check plugs/drain plugs. what are they used for?
Old Dec 2, 2004 | 05:44 AM
snatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zdowell17 &raquo;</TD></TR><TR><TD CLASS="quote">i dont know but i think you didnt get what i was tring to say! the two that are marked, i already filled. in that same picture on the very end of the tranny, it would be right next to the passenger side firewall, are another set of check plugs/drain plugs. what are they used for?</TD></TR></TABLE>
I don't know why you filled up 'both' of them, you don't have to. Only fill up the tranny from the top bolt hole shown in that picture, or fill it up through the VSS hole. No need to fill it up through the drain plug, then the fill plug. If you've filled it up through the fill plug (the top one in the picture), that's it. You're done.
I don't know of another set of check/drain plugs on the tranny. The two in the picture are it.
Old Dec 2, 2004 | 07:22 AM
if you look at the picture again. you will see in the bottom of the picture on the right hand side. there is another set on the case. they are a higher than the others. and by the way im not retarded, i didnt fill through the drain plug then through the fill plug.
Old Dec 2, 2004 | 07:51 AM
snatch's Avatar
On the right side of the pic, the lower one with the 3/8" square socket hole is to get to the snap ring if you want to open the tranny...no need to fill here.
The one just to the right of that, I'm not sure. There are bolts in that area for removing the spring and metal ball that holds the shift forks in place, but that tranny is so dirty it's hard to tell...but either way no need to fill there either.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zdowell17 &raquo;</TD></TR><TR><TD CLASS="quote"> and by the way im not retarded, i didnt fill through the drain plug then through the fill plug.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zdowell17 &raquo;</TD></TR><TR><TD CLASS="quote">the two that are marked, i already filled.</TD></TR></TABLE>
Sorry if I misunderstood you, but that's the way I read it.
Old Dec 2, 2004 | 08:32 AM
mattssi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zdowell17 &raquo;</TD></TR><TR><TD CLASS="quote">if you look at the picture again. you will see in the bottom of the picture on the right hand side. there is another set on the case. they are a higher than the others. and by the way im not retarded, i didnt fill through the drain plug then through the fill plug.</TD></TR></TABLE>
So did you put twice as much fluid in your tranny, oil did you just evenly distribute the oil between them. BTW I always use hondabond on the snap ring location to make sure that it doesn't slowly leak oil fluid over time. They tend to do that if you don't. Sounds like you have major binding issues though.
Old Dec 2, 2004 | 08:39 AM
msmotorsports's Avatar
There is also the pipe that is on top front of the tranny that is covered with a little rubber plug. Just put a hose on it and fill up the tranny that way. This is the only way I fill up the tranny and works just fine.
AR-cb7
Apr 8, 2008 09:27 AM
lsegcoupe
Oct 25, 2006 03:59 AM
fast+forward
Jan 19, 2004 02:03 PM
CBR600OnTop
Dec 30, 2002 05:04 AM
