car wont rev over 6800
Old Dec 1, 2004 | 10:11 AM
nvmyb20hatch's Avatar
Default car wont rev over 6800
just wondering if anyone has any ideas why my car wont rev over 6800. its a factory gsr ecu. i have coolant temp code, and spool solenoid valve code. any input would help a lot. thanks.
Shaun
Old Dec 1, 2004 | 10:37 AM
Default Re: car wont rev over 6800 (nvmyb20hatch)
ttt
Old Dec 1, 2004 | 11:04 AM
stevieteg's Avatar
fix those codes and'd you'll be in business. You car is running in limp mode right now. it won't rev past 6800 becuase the ecu thinks that the car is not warmed up yet.
Old Dec 1, 2004 | 11:07 AM
Default Re: car wont rev over 6800 (stevieteg)
i figured thats prolly what it was. i just wanted some opinions. thanks
Old Dec 1, 2004 | 12:02 PM
qcktegls's Avatar
yep just like he said change the codes and ull be golden
Old Dec 1, 2004 | 12:14 PM
Default Re: car wont rev over 6800 (qcktegls)
thanks for the input guys.
Old Dec 1, 2004 | 06:51 PM
97dxswap's Avatar
I had the exact same problem last month. Does your VTEC work? Are you throwing a VTEC OIL Presure Code 22 or P1258?
If so check your oil pressure switch ground. Ground the black wire that goes to the Pressure Switch directly to the frame if you have too. Solved my problem.
Old Dec 2, 2004 | 04:35 AM
Default Re: car wont rev over 6800 (97dxswap)
it is the oil pressure switch, vtec engages cause i have a vafc, but its throwing the code cause i have a jdm vtec solenoid with a usdm ecu. the jdm solenoid doesn't have the oil pressure switch, the usdm does. thats why i have that code. it took me 2 years to figure that out.lol thanks for the input, this is helping me a lot.
lshatch92
Mar 27, 2006 10:04 AM
hondacurab16
Sep 21, 2005 11:00 PM
mister2racer
10
Jul 1, 2005 08:14 PM
HondaFanBoy
Jun 16, 2005 11:25 AM
JKim0901
May 8, 2003 12:41 AM
