jdm h22a died please help
Old Dec 1, 2004 | 09:17 AM
Superman137's Avatar
Default jdm h22a died please help
My h22a just died. I went out to crank it today and it wouldn't start I kinda figured that the alternator was dead bc it had been giving me some trouble so I went out and got another one to make a long story short I checked to c if it was getting any gas and isn't so should I go ahead and assume that the fuel pump is gone and plan to change it out or could it be something elsee
Old Dec 1, 2004 | 02:31 PM
Elkins911's Avatar
Default Re: jdm h22a died please help (Superman137)
could be everything from your pump to your injectors. to check the pump the easiest way to do it is get a buddy to turn your key to the start position, you need to be standing next to your gas door with the cap off... listen very closely, if you hear a little buzzing noise that means that the pump is still working. when you have your key on the start position all your systems go through a check because everything is sent temp. power.
good luck
Old Dec 4, 2004 | 04:14 PM
check tha pump check the relay everything working but it's not getting fuel I mean I dropped the tank and then ran a positive and negative from the battery to the pump and it worked. But the pump isn't coming on when I put the key and turn it on
xjm92x
Mar 28, 2011 06:18 PM
quilksilver
Feb 27, 2009 05:41 PM
97civicgc
Jan 28, 2009 01:22 PM
Shaun
Jun 22, 2006 03:24 PM
22boost
May 13, 2006 04:44 AM
