ecu questions and i have no clue how this is possible
Old Nov 30, 2004 | 08:38 PM
mrnice1058's Avatar
Default ecu questions and i have no clue how this is possible
ok here is the deal i put a b16 civic in my 97 civic lx. i have a chipped p28 that i was running on it and it was mis-firing, acting funny and was not letting me get the engine going like it should. the ecu was idling at about 400 rpms to 600 rpms. so i took the chip out and then the engine was idling at 2000 rpms. now here is the kicker i put my stock 97 lx ecu in and it purred like a happy cat it was so smooth no mis-fire nothing i even took it for a test run around the block and it ran perfect. little problem but it is minor like antifreeze and a exhaust leak but it was running so good. now i don't know what to do next is the ecu shot? should i throw the chip out and get a new one? should get a new ecu? i need some advise thanks guys
Old Nov 30, 2004 | 08:53 PM
bluebird's Avatar
Default Re: ecu questions and i have no clue how this is possible (mrnice1058)
did you use a jumper harness obd2 to obd1?
Old Nov 30, 2004 | 08:55 PM
mrnice1058's Avatar
Default Re: ecu questions and i have no clue how this is possible (bluebird)
oopps forgot to tell you that yes i am using a jumper
Old Dec 1, 2004 | 05:33 AM
locash's Avatar
It could be due to the IACV, as the P28 looks for a 2 wire IACV, whereas the 96+ Civic DX/LX has a 3 wire IACV, if I am correct..
Old Dec 1, 2004 | 08:31 AM
mrnice1058's Avatar
Default Re: ecu questions and i have no clue how this is possible (locash)
nope i had that as a cel and i fixed it i thought it was it as well but it is not i am thinking it is the ecu because why would it do that?
Old Dec 1, 2004 | 08:39 AM
FerioVtec94's Avatar
id get a stock p30 ecu and try that, probably will run better then a chipped ecu anyways
Old Dec 1, 2004 | 09:39 AM
mrnice1058's Avatar
Default Re: (FerioVtec94)
so with the p30 i have to run the knock sensor right? i was going to do that this weekend my boy has one but it is also chipped! so i don't know what to do then
Old Dec 1, 2004 | 11:20 AM
yeah you would have to run the knock sensor but its only 1 wire to run, definitely worth it
Old Dec 1, 2004 | 06:54 PM
mrnice1058's Avatar
hey i will go for it let me see how it runs with my boys ecu and if there is a difference then i will get one but do you think that my ecu is bad or what? let me know what you think
Old Dec 3, 2004 | 10:31 AM
VTECVillain's Avatar
If you are not getting any CEL's then you can pretty much rule out the wiring and ECU harness. There's a lot of chipped ECU's out there that haven't been properly chipped and/or damaged in the process. Not to mention all the countless "make your car run like ***" chips that are floating around. It would be best to have your ECU checked out and possibly rechipped by a well-known ECU expert - contact Kenji, Katman (K@man), Newman, etc. here on H-T if you want to go that route. A P30 would best suit the motor if it's basically stock with minor bolt-ons.
Old Dec 3, 2004 | 05:12 PM
v4lu3s's Avatar
RTFM
when you took the chip out the ecu was in limp home mode.
you need to remove a jumper to unchip the ecu and force it to run on the stock p28 map.
DaddyKin
14
Jul 12, 2011 01:52 PM
LS stretch
Engine Management and Tuning
Feb 3, 2009 08:40 AM
95sloweg
Jan 14, 2008 05:46 PM
SiR99
May 29, 2006 07:34 PM
civiclxb16a
Dec 12, 2004 07:34 PM
