ITR Conversion no flamers plz
hey guys,
i guess the main question is how hard is it to convert a gsr to a jdm front end. I had a civic that i got into a wreck with and drilled out the spot welds in the core support and got that off fine. A guy i know at a body shop i shouldnt have to spot weld the new one on it will just bolt on with the bumper support. So im just wandering if the core support for a ITR will bolt onto where a gsr's core suport does. Any other info on this conversion would b helpful. Thank you.
ok i found this article https://honda-tech.com/zerothread?id=968968 and im wandering if u can replace the whole rad support or only able to do the top half
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg6racer »</TD></TR><TR><TD CLASS="quote">ok i found this article https://honda-tech.com/zerothread?id=968968 and im wandering if u can replace the whole rad support or only able to do the top half</TD></TR></TABLE>
You are correct. You only really need to replace the upper half.
Integra2nr
Dec 20, 2003 03:37 PM
