Please help need info on engine bolt name pic inside
Old Nov 30, 2004 | 12:36 PM
Negative3Five's Avatar
Default Please help need info on engine bolt name pic inside
Hey I broke the 2 bolts that are circled in green in the pic. I have a 94 GSR and went to tighten them back up and the stud just snapped...Could you tell me the name of em the price and if you know anywere that sells em...Anyone else broke em and know how much it cost to get it drilled out? Pic below not my engine found it on here just as a example
antzemail's Avatar
Bump my car...
Old Nov 30, 2004 | 12:41 PM
LSvtec03's Avatar
Default Re: Please help need info on engine bolt name pic inside (Negative3Five)
they are studs. go to a honda or acura dealer and tell them which ones broke, they have exploded diagrams. there are 2 different sized studs, so you need to make sure you get the right ones (looks like you need one of each anyway).
take off the valve cover and you can unbolt them with a deep socket 10mm.
Old Nov 30, 2004 | 12:43 PM
antzemail's Avatar
Yea I kno thier stud's was wondering what thier name was....
Old Nov 30, 2004 | 03:54 PM
Team 4R's Avatar
i busted one of those when installing my b18c.... i believe the honda guy called them 'those bolts that attach the valve cover to the head' or something like that.... that's the technical name of course.
Old Nov 30, 2004 | 05:14 PM
GWInquisitor14's Avatar
Default Re: Please help need info on engine bolt name pic inside (Team 4R)
Isnt the middle stud also partly the bolt that holds the cam covers on?
Old Dec 3, 2004 | 09:02 AM
antzemail's Avatar
BUMP
Old Dec 3, 2004 | 09:38 AM
omiehomie's Avatar
Default Re: Please help need info on engine bolt name pic inside (antzemail)
here guy go here and it has a dealership diagram for all the shizzle you might need
http://www.acuraparts247.com/s...e.jsp
and go to method 3 and it will display prices and everything!
Old Dec 3, 2004 | 09:40 AM
LSvtec03's Avatar
there's no proper name for it, dude. it's just a valve cover bolt. just checked on acuraautomotiveparts.org.
silly question if you ask me. why would honda name their bolts?
Old Dec 3, 2004 | 10:43 AM
purplegsr's Avatar
Default Re: Please help need info on engine bolt name pic inside (LSvtec03)
Bored at work today, the part you need should be called 'Bolt B, Head Cover
Old Dec 3, 2004 | 12:48 PM
EL Vap133's Avatar
Next time don't tighten them up so hard, they break easily.
Old Dec 3, 2004 | 01:25 PM
jayWknight's Avatar
Part numbers:
90014-PR3-000
90012-PM7-000
I bought spares just in case I ever break an another
The_Head
May 1, 2013 11:29 AM
xluben
Jan 15, 2007 06:03 PM
cslegacy
Jan 5, 2007 10:40 PM
Dres
Jul 7, 2005 11:33 AM
