ZC head on a Z6 block??
Old Nov 30, 2004 | 10:29 AM
SleepinT-REX's Avatar
Default ZC head on a Z6 block??
Alright, I tried searches, but I suck at knowing what to write to find what I need. I was wondering a few thigs... First, will a ZC head bolt on to a Z6 block. Second, are ZC pistons higher compression than Z6 pistons, and will they fit? Thanks for the help!
Old Nov 30, 2004 | 07:08 PM
dx2sicrx's Avatar
Default Re: ZC head on a Z6 block?? (SleepinT-REX)
an single cam zc head will fit but not the dohc as far as the pistons the pr7 pistons have a much higher compression than the p28 or whatever they are hope this helps
Old Nov 30, 2004 | 07:35 PM
v4lu3s's Avatar
RTFM
also look for p29 pistons they are very high dome too.
Old Nov 30, 2004 | 08:56 PM
bluebird's Avatar
Default Re: (v4lu3s)
What advantage are you trying to gain from using the non vtec head?
Old Nov 30, 2004 | 09:06 PM
FalkenSiR's Avatar
Default Re: (bluebird)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bluebird &raquo;</TD></TR><TR><TD CLASS="quote">What advantage are you trying to gain from using the non vtec head?</TD></TR></TABLE>
Exactly. Even though it is a bigger head, the vtec one has yet even better design.
Old Dec 1, 2004 | 09:38 AM
Default Re: (fast88std)
I was wondering about the dohc head, but since that doesn't fit, I'll just stick with the z6 head. I am turbo'in the engine, so I wanted a little higher compression, but still able to be boosted.
CRXguy_88
27
Feb 28, 2010 10:21 PM
CR3X
Jun 25, 2008 11:26 AM
nihad
Jun 4, 2007 06:39 PM
m1rocs
Mar 31, 2006 03:15 PM
c.dub
Mar 5, 2005 12:46 PM
