IACV questions
Old Nov 30, 2004 | 09:50 AM
Superdragr45's Avatar
Default IACV questions
well, soo far, i have almost everything hooked up again on my infamous ITB y8 motor. The last thing that stands in my way now is the IACV. My buddy who helped me last time came up with an idea to make some kind of blockoff with an opening to run a vacuum source to it...............im asking u guys to see if it would work.................gonna be cheap to make soo this is why we are trying it out................
Old Nov 30, 2004 | 10:57 AM
Default Re: IACV questions (Superdragr45)
bump
Old Nov 30, 2004 | 11:04 AM
klungemonger's Avatar
You should get one of those Golden Eagle vacuum manifolds that has all the ports on it. Make a plate that mounts the IACV on it and has 2 ports for the air inlet/outlet. the inlet side can just go off to the side and maybe use a little breather filter on it, then connect the outlet to the GE vac manifold. Run small hoses from the vac manifold to each of the ITB's...
Just an idea...
Old Nov 30, 2004 | 12:06 PM
Default Re: (klungemonger)
k. which side is the inlet and which is the outlet??? one hole has some type of cover on it that looks like a screen and the other side is open................which one should i cover with the breather and im guessing the other one should be sectioned off to a source of vacuum???
Old Nov 30, 2004 | 12:28 PM
I think the screen part is the inlet side (draws air from anywhere in front of the itb's or manifold...). Well, if you're looking at the holes, with the coolant nipples pointed down, the one on the left is the inlet, the one on the right is the outlet (goes to the manifold or itb's).
jdm_vtec
Sep 7, 2007 04:53 PM
b16ajdmrex
10
Dec 5, 2005 11:21 AM
darkirony
Sep 26, 2004 07:37 PM
scttydb411
Jan 31, 2004 08:59 PM
fo-do
Jan 10, 2002 12:47 AM
