Weird Idling when in park
Old Nov 30, 2004 | 09:19 AM
newhondaowner29's Avatar
Default Weird Idling when in park
Only when I am in park and no matter wheather the engine is cold or hot I get this crazy idling problem it goes from 1500 rpm down to 1000 rpm, back and forth like that with a second in between. Any opinions welcome.
Old Nov 30, 2004 | 09:55 AM
Filthy Focker!'s Avatar
Default Re: Weird Idling when in park (newhondaowner29)
It should do that in neutral to right?
Can be an intake leak
or the IAC sensor. You will need to rmove it and try cleaning it with mineral spirits and a toothbrush. If that does not work, you will need to replace it.
fs
Old Nov 30, 2004 | 10:01 AM
Default Re: Weird Idling when in park (filthy_shovel)
It only does it in park.
Old Nov 30, 2004 | 10:05 AM
What???? Only in park. Not in neurtal?
fs
Old Nov 30, 2004 | 11:36 AM
Yes sir I know it be wierd, but I am sure that it is only in park when it does this.
Old Nov 30, 2004 | 01:41 PM
91EXRMANUAL
Guest
Posts: n/a
Park and nutrual are virtually the same thing... they both idle at this state freely
there should be no diffriance..
Old Nov 30, 2004 | 02:18 PM
Default Re: Weird Idling when in park (91EXRMANUAL)
Well maybe I didnt give the nuetral position enough time to do this, but I did it twice once while cold and another time while hot and both times produced the same result nothing but smooth steady idling.
Old Dec 1, 2004 | 05:32 AM
Anybody, Anybody?
Old Dec 1, 2004 | 08:42 AM
Open the hood and check if any hoses are unplugged or cracked...
Also, is your check engine light on?
fs
Old Dec 1, 2004 | 02:36 PM
Filthy,
Thanks for helping. No engine lights are coming on.
I had to replace a stud bolt that seats the fuel rod on top of the intake manifold because when I went to clean out my egr ports and put everything back on the top of the bolt broke of when securing the nut over the fuel rod!! I think it might be possible that the pcv valve was loose or one of those hoses connecting to the fuel rod were lose, because now the idling seems to have returned to normal.
VTECchris
Nov 7, 2008 11:20 PM
Boostn B20
Oct 30, 2008 07:04 PM
2000civicsi
10
Oct 26, 2005 04:05 PM
hatch4raceb16
Jul 6, 2004 06:33 AM
stRtypR25
Jan 12, 2003 03:09 PM
