ek hatch rear disc conversion ???
hey
I have a complete rear disc setup out of a 95 ls integra (e-braake cables fluid lines and all. my question is that they are abs. and my dx is not can they still be used on my car ??? and if not what else do I need??? I was searching and people say I can use the integra cables. even though there to short. also does anyone know if the front brakes off the same car will work on my 98 civic also???? I was also reading about changing the master cylinder and booster off the same integra and it will work better. any help will be appreciated. plan on doing it this weekend. thanks
searching wouldve answered all your questions...been covered hundreds of times
No, abs doesnt work that way...so YES they will be fine
Integra cables will be fine on your hatch. If youre REALLY concerned about it order some cables from japan or europe's ek4/ek9 (but you dont have to)
Yes, a larger mc/bb combo from an integra (1" or 15/16")is the way to go.
Contact Leo at passwordjdm.com for jdm itr units
or look on ebay/classifieds here for usdm integra sets
Each perform the same...where you get it is up to you
i have gone from 13/16 to 15/16 and now to 1" go with 1" with an integra booster it is a much more solid brake feel than the 15/16.
i figure my experience will save you some money in the long run...
while your at it...take the sway bars and lower control arms for the front and rear. The Front brakes will be an upgrade too.
To use the rear sway bar...you'll need new end links and mounts from an SI
mikeymike413
Suspension & Brakes
May 22, 2022 12:18 PM
import-tooner
May 8, 2009 01:52 PM
aznphantoms
Dec 7, 2004 04:20 PM
